How to: Stock WGA spring mod
not true, pump gas users may still want to run more than 21 psi at red line. Stock turbo tapers down that low with stock WGA so pump gas people may want 23 at redline.
like anything else it depends on your tune/tuner
with adding more mods once you get timing, fuel, boost line up will always = more power
thanks dudical for the responses bro
Yea it is, but there is no point in asking how much more power this will make since like I said adding boost will add power according to what other mods you have.
One person may see 1hp from this while another might see 20hp at redline.
However, they will both see an additional 2psi or so at redline so that is how this mod should be quantified.
Overall you should view this mod as a way to hold more boost till redline, yes that should mean more power but will require more tuning.
I get about 15-16 psi straight wga pressure; my eyelid is turned all the way down. 3rd gear pull I spike around 30psi and taper to 26ish psi @ 7500 and 4th spikes to 30 and sits there I think it tapers to 28ish. Dont quote me because i really dont remember, since I like to keep my eyes on the road going that fast. But I know for a fact it sits @ 30 psi for a while.
K..I did the spring thing...then I kept hitting over 30 psi and not matter what I did with my MBC the boost wouldnt' come back down. I took the spring off and turned down the MBC almost all the way. Now I am spiking 30 psi and falling to 20. I am thinking that I may have turned the eye on the WGA the wrong way. I screwed it in towards the actuator. Tomorrow I will have to figure out what I did wrong. It's late now. Any suggestions?
