How to: Stock WGA spring mod
Old Apr 28, 2014 | 09:33 PM
  #91
Nimpoc's Avatar
MrFred, you're an admitted picky guy. Why did you go with this mod instead of an aftermarket actuator (which you had NIB for a while)?
Old Apr 29, 2014 | 06:37 AM
  #92
mrfred's Avatar
I started using it long ago on the stock turbo, and its a bit of a PITA to R&R an actuator when the turbo is on the car. This was much easier to install, and it's worked great, so I've stuck with it. The actuator I had in the garage for a while was a dual port (push/pull) version that I was considering using to try to tame the annoying boost-o-matic response of the stock Evo 9 turbo. Once I switched to the BBK, I didn't need it.
simons3z
13
Feb 3, 2017 03:52 PM
alexc
Jun 20, 2016 07:14 PM
REVOlution X
36
Oct 16, 2012 08:59 PM
tseitz123
Feb 6, 2008 09:14 AM
bnice01
64
Aug 15, 2007 11:42 AM
