How to put wing back on??
Old Mar 15, 2008 | 09:12 AM
RoBear's Avatar
So I've searched and there's quite a bit about how to remove the wing (bolts/adhesive), but I couldn't find anything about how to put it back on.
I figured that you just replace the bolts, but what about the lack of adhesive? Do you guys use some kind of adhesive to replace the old stuff, and if so, what kind/how to?
Do you leave it without adhesive, and if you do, is there any noticeable difference (gaps, lifting, etc.).
Thanks for your help, gents.
Old Mar 15, 2008 | 02:44 PM
RoBear's Avatar
anybody have any advice???
Old Mar 15, 2008 | 02:48 PM
vvhiteix's Avatar
when i had mine off....the adhesive was still good to use...just had to heat it... but if anything...its basically 3m double sided tape.
Old Mar 15, 2008 | 02:50 PM
RoBear's Avatar
I appreciate the help...man I'm gonna have that 3M tape ALL OVER my car by the time I'm done playing with it.
Old Mar 15, 2008 | 03:38 PM
deepee1's Avatar
Pretty straight forward. Double-sided 3M foam does the trick. You only need a couple of thin strips - check wing underside for shape guidelines.
If you have the bolts - just make sure you have the two plastic plugs.. one either side. I took mine off with the wing, then ordered replacements when it went back on.
Tighten everything up - the rubber bumpers need adjusting. You're good to go.
Old Mar 15, 2008 | 04:19 PM
H.Redman's Avatar
NO Dont put it back on. J/P. Like the others said, 3m will work just fine. But really tho, it looks better without it
Old Mar 15, 2008 | 04:40 PM
vvhiteix's Avatar
no prob.
Old Mar 15, 2008 | 06:57 PM
RoBear's Avatar
Thanks for all the input!
lancerarmstrong
Evo X How Tos / Installations
92
Feb 19, 2020 10:11 PM
Kirabi
Oct 6, 2016 08:22 PM
RATEDX
Apr 9, 2016 06:23 PM
phishy
30
Feb 21, 2016 01:33 AM
gvr4737
Nov 19, 2009 02:32 PM
