exhaust leak after turbo swap
Old Dec 30, 2008 | 10:30 AM
pjb00stin's Avatar
hey guys,
this past weekend i installed my ix turbo and titek o2 housing.when i started the car,you can here an exhaust leak,but only when the RPM's start to drop.For example if i rev the motor to 2500RPM's,you can here it when i let go of the gas..you can here it a little at idle.i checked almost everywhere i could think.It sounds like metal gasket hitting another metal gasket.The sound is coming from the left side of the motor.Any ideas where else to check?thank you
pj
Old Dec 30, 2008 | 11:46 AM
20gmr's Avatar
well man Not sure what to tell you thats not already obvious. the only places it can leak really is between the mani and the head the mani and the turbine inlet, o2 housing and hotside, or o2 to downpipe.
Old Dec 30, 2008 | 12:47 PM
pjb00stin's Avatar
do you know the toque setting for the bolts that connect to the mani?
Old Dec 30, 2008 | 12:53 PM
Kracka's Avatar
Did you reuse or replace the gaskets? I say pull it back apart and find the faulty gasket and replace it (or replace all while you're in there).
17579EVO9MR
13
Oct 26, 2010 12:53 PM
kmcconn9
24
Oct 5, 2009 03:43 PM
evascst
Nov 17, 2008 03:25 PM
willum14pb
Sep 3, 2006 12:39 PM
initialDRacer
Lancer Aftermarket Forced Induction Tech
23
Jan 31, 2006 10:23 AM
