Removing the steering wheel column
Old Sep 13, 2003 | 02:49 PM
Nightfall's Avatar
i am trying to install my HKS type one TT but im unsure as how to remove the steering wheel column. can someone fill my dumb *** in on how to do it? thanks!
Old Sep 13, 2003 | 03:34 PM
Nightfall's Avatar
come on guys i really need help with this for my evo. i know you guys are smart. come on!
Old Sep 13, 2003 | 03:46 PM
Nightfall's Avatar
hahahah i answered my own question. easy ****. dunno why i couldnt do it before..........
Old Sep 14, 2003 | 05:49 PM
SillySpheres's Avatar
It you didnt get it yet, here are the steps. It is really quite easy:
Tools needed: long Phillips head and 10mm socket wrench
- remove the bottom of the dash by unscrewing the two screws at the base, the 10mm bolt behind the tray, and unsnapping the various clips. Then unplug the dimmer and headlight leveler. The whole piece should fall out
- next remove the steering column. There are two screws underneath the column next to the end of the lever. There is one final screw that is underneath towards the back. It is tough to get to because it is at the very end of a long tunnel.
- once those 3 bolts are off, the column just snaps off.
Old Sep 24, 2003 | 10:55 AM
webguy330i's Avatar
Just to clarify here, you need to remove the 10mm nut behind the hood release latch also.
The clips holding the foot well piece into the dash simply pop right out. Raise your steering wheel all the way up to pry out the right side of that piece.
Also when you are putting things back together, release the steering wheel tilt lever. I kept trying and cursing the lower portion of the steering column and then I realized my stupidity.
Old Sep 25, 2003 | 09:55 PM
Thoe99's Avatar
LOL, I did the same thing when I installed my turbo timer! Except I used brute strength and screwed it back on. It would keep popping off. Finally I bowed down to my stupidity as well.
Old Sep 26, 2003 | 06:24 AM
webguy330i's Avatar
Thoe99, feels good to be humiliated by your car doesn't it?
lemon_head
Nov 24, 2025 10:59 PM
villix7
May 3, 2023 07:45 PM
The_X_Effect
Aug 13, 2017 10:44 AM
nacsa
May 19, 2017 12:06 PM
GSX_TO_EVO
Feb 13, 2017 12:48 PM
