How To: Boost leak tester for $5.02
Old May 30, 2008 | 02:28 PM
  #31
Evoryder's Avatar
HomeDepot, Discount Auto Parts
Total = cap,connector,valve stem approx $15
Tbolts were $6 or so...
Old Nov 22, 2008 | 08:34 AM
  #32
illmatic165's Avatar
nice writeup
Old Jan 23, 2009 | 12:14 AM
  #33
H8my8's Avatar
awesome write up, thanks man.
Old Sep 14, 2009 | 08:40 PM
  #34
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
umm kinda of a noob question but i read something about capping the pcv valve? how do i go about doing that and is it necessary
Old Sep 23, 2009 | 11:49 AM
  #35
vint21's Avatar
besides the throttle body seals, where are some other sources of leaks?
Old Sep 27, 2009 | 08:13 PM
  #36
EVOlution561's Avatar
awesome write up.
Old Oct 4, 2009 | 02:31 PM
  #37
Jhutterer's Avatar
Good writeup I just built this today.. Going to preform the test soon.
Old Oct 12, 2009 | 01:00 PM
  #38
EvolNinja's Avatar
Awesome write up! I thought the boost leak tester was more than a coupler with endcap with valvestem on the end. Now I can make my own and test it once it get a bit warmer.
Old Oct 15, 2009 | 04:16 PM
  #39
ronitlancer's Avatar
im so confused as to what i did wrong. but i have a boost leak tester and 125psi compressor but i couldnt get my turbo to start spinning. i guess im using my compressor wrong somehow but i set it to 25psi and it said it was pushing out 25psi on the out-regulator-gauge yet my turbo didnt spin at all and my boost gauge read nothing. i got scared and put my intake and everything back on and took it for a drive and everything seemed fine.
Old Dec 18, 2009 | 07:08 PM
  #40
Evo_IX_Guy's Avatar
ok, I know this is a noob question but the car need to be turned on for this? Or just on to read the gauges but not the engine?
Old Dec 20, 2009 | 06:55 PM
  #41
Jhutterer's Avatar
No the car should not be on.. The point of this test is to fill the engine with pressure, simulating what a turbo would do when your running the car. You need the car off to hear leaks.
Old Dec 20, 2009 | 07:05 PM
  #42
wizzo 8's Avatar
I/C pipe conections, BOV if its weak, Throttle body gasket, I/C itself if something has puctured it such as a stone hitting it, Any vacuum hose, Intake manifold. Hope that helps
Old Jan 11, 2010 | 02:02 PM
  #43
november's Avatar
Thanks for the write up - I will use this to test mine - I bought it used, never hurts to make sure the car is running in tip-top shape.
Old Mar 23, 2010 | 12:49 AM
  #44
m1stuhk1mch1's Avatar
i tried the same thing today and i found that there is a hissing noise followed by a complete loss of pressure (i can only assume it is a giant leak), right at the throttle body. does anyone know if this is definitely indicative of a throttle body seal leak? any input would be great because my car has been hesitating under boost and im not sure if its the clutch or a leak..
Old May 4, 2010 | 08:58 PM
  #45
EVO8emUp's Avatar
IsOs the O.D. of the stock turbo (2005) inlet 2"?
