How to replace O2 housing (pics)
Old Sep 15, 2008 | 06:06 PM
  #46
Aman's Avatar
megan makes good stuff, but went evomod o2 dumpp btw nice write upp
Old Sep 27, 2008 | 01:33 PM
  #47
dwnfdrknss's Avatar
k guys i just put mu invidia O2 on and i turned on the car. started up fine but after a couple of seconds the car started steaming. it doesn't seem like its coming from anywhere in particluar. My thought is thats its the PB blaster steaming up but im not sure. should i just leave the car running and see what happens or....????? any ideas???
Old Sep 27, 2008 | 02:17 PM
  #48
marksae's Avatar
Yeah, it's most likely the PB blaster burning off causing the steaming. It should burn off after a few miles of driving.
Old Jan 18, 2009 | 09:00 PM
  #49
ronitlancer's Avatar
OP, I want to makeout with your face. I dunno how I didnt find this earlier.
Old Sep 16, 2009 | 06:02 PM
  #50
spoolinx's Avatar
about how long does it take to get the job done if all goes well?
Old Sep 18, 2009 | 02:55 PM
  #51
D-Mon3y69's Avatar
Looks like an awesome write up. Thank you for taking the time to make it. Guess tomorrow i'll install my MAP o2 dump with this helping me. Ugh haha thanks again.
Old Sep 20, 2009 | 10:25 AM
  #52
D-Mon3y69's Avatar
take the radiator out!!!! i wanted to try to do it with out, now i'm in here commenting well its draining out side ugh
Old Sep 28, 2009 | 12:10 AM
  #53
jasonn's Avatar
A little tip since this thread has helped me immensely with my install. Instead of using a torch, since some of us do not have access to this, you can PB blast it, leave it out in 100 degree sunlight and use an 02 remover to take it out.
http://www.amazon.com/gp/product/B00...14ETRXZE8V3H2H
Old Oct 22, 2009 | 09:45 PM
  #54
4G63K's Avatar
DId anyone do this install with a Buschur DP. The Buschur DP dosent use the Donut Gasket..
Old Nov 21, 2009 | 10:10 AM
  #55
visyoual's Avatar
i have some horrible bolt shear action going on.. anyone have any idea where to get bolts on a weekend? desperate need over here. F*(&$%^()!
Old Nov 21, 2009 | 10:12 AM
  #56
visyoual's Avatar
sorry for my breach of manners, very good write-up. wish i had caught it sooner. F@#$%*(&(*)& PB blaster + Torch and still sheared a bolt off in the turbo side.
Old Nov 21, 2009 | 10:16 AM
  #57
Thrilla's Avatar
Veteran: Army
You can try Rockville mitsu, or one of the local shops in your area. I see your in MD, there's a few evo shops local to you. Give them a call since you need it ASAP.
Old Nov 22, 2009 | 07:43 PM
  #58
visyoual's Avatar
all is well now. oxy acetylene (spelling uncertain) Gibbs penetrating spray and some reverse threaded drill bits, a little tapping action, and presto! New MAP eliminator pipe installed and it is absolutely worth all of the effort. Scaring pedestrians in a three block radius is indescribable. And the bolts wound up coming from advance auto (10.5 grade steel flange bolts). Mitsu bolts would have been better bit ill take what I can get. Thanks for the help peoples.
Old Feb 28, 2010 | 07:34 AM
  #59
cij911's Avatar
How did you bleed the system ? You could have air in the system and cause intermittent over-heating, no ??
Nice write-up by the way!
Old Apr 20, 2010 | 10:19 AM
  #60
eb66's Avatar
I didn't see this mentioned anywhere, but it helped me out a lot. Go buy a 14mm open ended stubby wrench to get into the tight spaces around the o2 to turbo bolts. I got mine at Sears. I'm not sure where else they have them.
