Noise sounds like the front right corner
Old May 13, 2009 | 07:23 AM
Eastside's Avatar
I have a 2006 evolution 9 MR not that it matters much.
It has a noise and maybe I can feel it. I'm just confused by the whole thing.
It happens under hard braking, and then again under hard acceleration. Like something is moving fore and aft. Quite loud clunking to describe it. Sounds like the front right from the drivers seat. Any thoughts?
It happens with the clutch in or out under braking.
I haven't figured out a way to move forward quickly with the clutch in.
So that's just with the clutch out.
Help?
I hope this is the right place to post this. I apologize if this is the wrong forum.
Old May 14, 2009 | 08:34 PM
KenMasters's Avatar
Exhaust hangers?
Old May 14, 2009 | 08:38 PM
dxbtune's Avatar
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
Maybe your down pipe is touching...
If its stock then no but i had the same issue and had to dent in the DP a bit and heat wrap it there since it was close tot he oil sump too...
Oh and I suggest you jack up the car and have a good look
my 2 cents
Old May 15, 2009 | 09:53 AM
Eastside's Avatar
Stock and 3000 miles.
This feels like something suspension related.
I have had it up in the air. nothing seemed a miss.
I am going to take some stuff off today and see if I can come up with anything.
Old May 15, 2009 | 10:02 AM
spdrcr456's Avatar
strut mounts?
Old May 15, 2009 | 10:07 AM
Lukelis's Avatar
brake pads?
Old May 15, 2009 | 06:07 PM
KenMasters's Avatar
Check for blocks in the springs, some dealers forget to take them out.
Old May 18, 2009 | 09:20 AM
Eastside's Avatar
It seems like the strut mount to me.
Although it seems fine.
I have re greased it and we'll see if there is any change.
Anything else to check with the mount?
I don't see how the brake pad could make this noise or feeling but from what is going on that would make sense as well.
Take it off and put it back on?
Check what do you think?
And there is no anything in the springs.
The car has been driven well.
I'm lost I don't want to go to a dealer but aside from replacing things I don't know where to go.
Old May 18, 2009 | 09:33 AM
tweakdsm's Avatar
how many miles on the car? maybe your t-case? i dont think has to do anything with suspension. put the car on the lift, go thru gears and inspect it...
Old May 21, 2009 | 04:24 PM
Eastside's Avatar
3000 miles on the car
Old May 28, 2009 | 11:01 PM
dxbtune's Avatar
so what was it?
Old Jun 5, 2009 | 05:10 PM
Eastside's Avatar
lower control arm and the top strut isolator. I haven't had a chance for a proper shakedown . But it seems to be sorted. just got done today
Old Jun 27, 2009 | 08:03 AM
Eastside's Avatar
and the noise is back. or at least it was heard a couple times. we'll see
sktng22
18
Dec 12, 2013 06:22 PM
Enjoi926
29
May 18, 2010 05:11 AM
eag36
Apr 17, 2007 05:29 AM
drewblueeye
Feb 28, 2007 04:40 AM
HoustonEvoVIII
15
Feb 11, 2004 08:09 PM
