Front Sway Bar Install
I was going to install mine but you have to drop the front cradle down to install a new one. Look at the service manual, it shows everything that needs to be taken out to get the sway bar out.
When I install the new clutch I will install the new sway bar, no sence in doing that much labor twice.
Ditto what superz said I have ridden in a few evo's at an Autocross and it will give you more understeer you need to upgrade to a Cusco three way adjustable rear bar. I also have ridden in an evo with this upgrade big improvement
I already have the bigger rear sway bar and sway bar end links, next is the front, then coil overs. In order to compensate for the larger sway bar in the front cant you just set the dampening rate higher in the back than in the front to increase overstear
Took off all of the bolts and tried to fish it out, but could not get it out. Then looked at the service manual and it mentioned dropping the entire front cradle. Put the OEM front sway bar back in as I don't have a lift at my house to do this. When I put my new clutch in I will change the sway bar.
OZRaLLyDJ
Mar 15, 2005 10:01 PM
nickawd
Mar 9, 2004 10:54 AM
