How To: HVAC Double Din Mod
Old Aug 5, 2009 | 04:28 PM
Duh Panda's Avatar
how much would you charge... im down for this
Old Aug 28, 2009 | 03:29 PM
jba3's Avatar
+1 on cost and stuff
Old Sep 2, 2009 | 05:01 AM
streetracerkam's Avatar
Me 2.
Im not the neatest person, so this isnt something I want to tackle. PM me with pricing.
Old Sep 2, 2009 | 09:31 AM
wd_cross's Avatar
+1 pm as well pls!
Old Sep 2, 2009 | 08:08 PM
MR TONY's Avatar
^^ PM me too. I'm up for sending mine!
Old Sep 14, 2009 | 06:51 PM
cyanide's Avatar
Lower HVAC Bezel
Originally Posted by streetracerkam
me 2.
Im not the neatest person, so this isnt something i want to tackle. Pm me with pricing.
Leave your email address for me to be able to reply. You can also send a text message to the number before @. I've recieved messages and no contact info has been left, so please don't forget...
Attached Thumbnails How To: HVAC Double Din Mod-101_0513.jpg
Last edited by cyanide; Sep 5, 2010 at 06:01 AM. Reason: Recieved a text message with no contact info.
Old Sep 29, 2009 | 11:19 PM
klever's Avatar
I need this done on my evo pronto...
Old Oct 15, 2009 | 08:13 PM
MatosEvo's Avatar
Seems simple enough to do. I think Ill try my hand on it.
Old Nov 9, 2009 | 09:25 AM
REV.olution's Avatar
nice, this is something I will not be trying, at all.
Old Dec 16, 2009 | 11:25 PM
4g63girl's Avatar
Can we see some install pictures? I was actually staring at my dash the other day thinking this would work! But I thought it would look retarded with the controls tilted down, not up... but then I was driving another evo with the triple lower gauge pod... and they are tilted up... Not sure if you could manipulate them enough to fit properly, but it's an idea.
This is the piece I'm talking about:
http://www.streettunedmotorsports.co..._lower_pod.htm
Old Jan 13, 2010 | 06:29 PM
stevoooo's Avatar
Originally Posted by cyanide
pm... or leave your email address @ 7874106297@txt.att.net with HVAC as subject.
where are these available?
Old Jan 26, 2010 | 01:50 PM
dead_pirate's Avatar
Wow that's insane... What I don't understand is one of the last steps... When u slide the whole AC panel you sand the hell out of and put it into that little slot, the plastic peice just stays in there? You dont seal it up or anything?
Old Feb 7, 2010 | 01:45 PM
SRT-TO-EVO's Avatar
I don't understand your question pirate. If your talking about the whole module behind it, then no no sanding is required, although you have to modify one if the brackets behind the dash to slide it down there. Don't know what your sealing either?
Old Mar 25, 2010 | 02:04 AM
DE31's Avatar
thanks for the how to. i followed every step and added some myself. worked out great, more than worth it if you have the time and the patience.
btw i found that using painters tape layered a few times creates a cleaner cut with the dremel, plus i was able to draw a guide line on the tape for the initial cuts.
also cut a piece of paper as a quick guide for the size, although the actual piece ended up a little bigger than the piece of paper.
Finished and painted flat black, will redo the finish in matte.
last tip, its something i have in mind for the near future. i find that some light leaks through the corners so i plan to get some really thin foam gasket things from home depot to seal the edges better.
Old Jul 14, 2010 | 12:13 AM
MetalSpoolDoom's Avatar
So how hard is it to relocate the Hvac controls (Mechanics behind it) after you do the above steps. I would really like to see some info on how to complete the rest of it.
And than from here you essentially just buy the Double Din JDM top part and install is ready to go?
