How To Dynamat your doors (lots of pics)
Old Dec 10, 2009 | 04:34 PM
  #31
Gazika's Avatar
nice and clean , how much time does it take ?
Old Dec 10, 2009 | 05:07 PM
  #32
Ev0ikon's Avatar
How much weight do you think it would add to do all 4 door? How about the floor?
Old Dec 10, 2009 | 06:45 PM
  #33
atombomb33's Avatar
EvoM Community Team
Why all the worry about weight? The entire Dynamat Extreme door kit weighs 5.4lbs. And there is enough in the kit to cover two doors. So, if you go with two door kits to cover all four doors, you're talking about 10.8 lbs. That's nothing.
Old Dec 11, 2009 | 09:41 AM
  #34
Ev0ikon's Avatar
LOL. I didn't realize it's that light. I mean, I pack that much at a buffet line!
Old Dec 16, 2009 | 09:10 AM
  #35
bomjoon's Avatar
i have some dynamat laying around... i might do this...
my doors dont rattle so i didnt need it but i guess the sealing witht the stuff helps...
Old Jan 10, 2010 | 05:33 PM
  #36
guapoholic's Avatar
Once I saw door panels come off and wires sticking out, I didn't even finish reading the write-up..
Old Feb 3, 2010 | 10:41 PM
  #37
Cyp's Avatar
Cyp
Originally Posted by clipse90gsx
thats a good idea but the only thing i can wrong with it is what if something happens to your power window motor or your window falls off track or something like that.
why didnt you put it on the inside of the door instead of right behind the door panel?
good question. Can someone answer?
Old Feb 14, 2010 | 01:20 PM
  #38
Evo1001's Avatar
if that happens you can always remove part of the dynamat, fix the window problem, then reseal with a new piece of dynamat. It bonds very good to itself, so you can patch it as you like.
Old Feb 14, 2010 | 01:24 PM
  #39
Evo1001's Avatar
It took me about 4 hours for the dynamat + installing new speakers w/ crossovers. If i were to do it again, now that I know what's involved, probably 2 hrs.
Old Feb 14, 2010 | 01:32 PM
  #40
Evo1001's Avatar
Originally Posted by cedric
Does the stuff also help reduce road noise? or is that something different.
It should, I can hardly tell, but if you do the whole car, you would be able to notice it. The purpose for this is to remove door rattles and improve sound, which it did 100% for me.
Old Feb 14, 2010 | 10:53 PM
  #41
Cyp's Avatar
Cyp
^what speakers did you get? did you put sound deadening on the outer door?
Old Feb 14, 2010 | 11:34 PM
  #42
Evo1001's Avatar
these below. no fitment issues. sound very good (but if you want very deep bass, get a subwoofer too). You can't see here, but each speaker has a small push button on the front for you to choose tweeter setting (-3db or 0 db).
http://www.sonicelectronix.com/item_...ppa+62.9I.html
Looks like they went down in price, i paid $100 per set a year ago.
I'm not sure what you mean by "on the outer door", but if you mean the outermost door wall, then no. just look at the pictures.
Old Feb 15, 2010 | 09:07 AM
  #43
Cyp's Avatar
Cyp
^Yes, that's what I mean. Is there a reason why you say no?
Old Feb 16, 2010 | 05:35 PM
  #44
Evo1001's Avatar
I don't know what the inner compartment of the Evo 10 looks like, but for the evo 8/9 there is no room to do it, except for the hole to the right of the speaker, but IMHO it won't do anything for you, if you put dynamat inside there. I think the purpose to dynamating doors is to cover up all the holes in your door structure and make it more solid like a sealed enclosure for your speaker which will benefit the sound.
You can call up your local audio/install shop and see what they recommend, because i'm not an expert in this matter.
This is my before and after
Old Jun 16, 2010 | 01:09 AM
  #45
byebyeV8's Avatar
Thanks for the write up
Thanks for taking the time to post this how to. I'll be doing this very mod when my speakers come in. Hadn't planned on doing the dynamat until I came across this write up, now it seem dumb not to do it while I'm in there.
How is it holding up? Looks like it should be pretty much maintenance free. I like your idea for the x over, must be some sticky stuff if you trust it to hold like that. Did you have any problems with the door handle rods? Looks like you didn't use the guide clips.
