HOW TO: Install Accusump
Old May 19, 2011 | 09:24 PM
Renxo's Avatar
Great thread, I think you have the 2qt reservoir, I've just received my kit but they send me the 3qt reservoir, would you think that the 2qt is better and I should change it or it would just work the same? Thanks in advance for the info cheers.
ps: sorry for my english, haven't practice it recently 3:
Old Feb 22, 2018 | 05:56 AM
boostedup's Avatar
oil filter housing
old post i know but is this the correct place to install the line for the accumulator? does it not need a one way check valve in the system to stop the oil flowing back into the pump? is there a one way valve in the filter housing behind this point somewhere so the oil only goes to the engine in the event of an oil surge situation??
Old Sep 3, 2020 | 09:55 AM
SoSoEVO's Avatar
Bump has anyone else installed an accusump, how has it responded at the track, street driving, etc? Thinking about adding an accusump before I start taking the evo to the track more regularly. Any info would be greatly appreciated.
Thanks!
Old Sep 5, 2020 | 12:27 PM
CDrinkH2O's Avatar
I'm mostly street with occasional track running 450 / 400. I have the 4qt Accusump with an electronic valve mounted in the passenger footwell, plumbed in to a sandwich plate between filter and housing. I have run it for the past 8 years and 150k miles
Before Accusump: Oil starvation and pressure drops on long right handers resulting in three full engine rebuilds due to rod end bearing failures.
After Accusump: Pressure drops are eliminated by the accusump. No more rebuilds! Huge amounts of downtime and money saved!
Old Sep 7, 2020 | 04:18 AM
EVO8LTW's Avatar
Thanks for sharing. Which sandwich plate? Have any photos?
Old Sep 7, 2020 | 01:22 PM
CDrinkH2O's Avatar
I think it was this one: https://www.cantonracingproducts.com...-2-5-8-gasket/
jid2
May 13, 2019 11:37 AM
jid2
22
Jan 26, 2016 03:17 PM
jid2
Jan 10, 2009 09:31 AM
jid2
Jul 3, 2008 09:24 PM
