Removal/Installation of the stock turbo
Old Nov 3, 2003 | 06:09 PM
BadBoyBeltran's Avatar
Does anyone have any instructions (pics if possible) on how to remove/install the stock 16G? Thanks guys!
Old Nov 24, 2003 | 06:57 PM
1QWKEVO's Avatar
its not very hard...... DRAIN FLUIDS!!, then simplely remove the rad fan, rad if needed... heat shields, IC pipes, intake pipes, ehxaust manifold, dp, unbolt the turbo and if possible remove in two pieces if not attempt to make clearance for the while unit to come out as one... Remove the 2 water lines, oil feed line, and oil dump tube.... You will see waht you need to remove when doing so.... If you don't then you shouldn't be removing your turbo...
I did a turbo and monifold upgrade on my GSX in like a few hours, jsut opened the hood and started to remove stuff, not a single leak on it and car was good for 12 sec passes....
PCToolsWiki
60
May 9, 2016 10:26 AM
skylinegtr35
Evo X How Tos / Installations
Sep 24, 2009 02:30 PM
bolsen
Jun 2, 2008 06:13 PM
jayson2k2
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jan 23, 2007 01:31 PM
Blue Evo 8
Nov 28, 2005 11:46 PM
