Wiring in lights for gauge
Old Nov 10, 2003 | 07:41 AM
fastmarsh's Avatar
Question Wiring in lights for gauge
where did you wire in the lights for the gauges? what is the easiest place to do it?
Any info would be appreciated as I don't want to start splicing into wires that I'm unsure of.
Any pics are also appreciated.
Thank you
Old Nov 10, 2003 | 07:43 AM
nastea's Avatar
i bought some mini fuse taps, and taped into the instrument panel circuit for mine
Old Nov 10, 2003 | 07:47 AM
Fireball's Avatar
I tapped into the light for my cigarette lighter.
Old Nov 10, 2003 | 07:54 AM
fastmarsh's Avatar
On the cig lighter, how did you get to the wire? Did you have to remove the center console?
Where did you ground it?
Old Nov 10, 2003 | 10:20 AM
Fireball's Avatar
Yea, takes me 5 mins to remove the center console. For the ground, I just connected to the frame underneath the steering wheel.
Old Nov 10, 2003 | 10:21 AM
helli0n's Avatar
Check this article from evom's install of Defi gauges...its got info on the wiring...I used this information to install my Apex'i which I hooked up the light for the headlight adjuster...
https://www.evolutionm.net/features/...rojectevo/24/3
Old Nov 10, 2003 | 01:15 PM
evo_007's Avatar
All sources for gauges are available from the headunit harness. I managed not having to cut any factory wires by using adapter harness from Metra. You can even have the gauges dim with the dimmer if you want.
Old Nov 10, 2003 | 01:25 PM
93civEJ1's Avatar
i tapped into the air conditioner lighting
Boosted_EvoVIII
Mar 12, 2012 03:19 PM
dylan_EVO_VIII
Nov 27, 2011 06:20 PM
smokey
Apr 19, 2006 05:53 PM
zze86
Nov 1, 2005 01:01 PM
fixem2
Jun 14, 2004 07:48 PM
