forge recirc valve which spring needed?
Old Dec 4, 2003 | 08:50 PM
evoego's Avatar
Registered User
I am aboutto install this recirv valve andwas wondering which spring seeem to be working the best . I have the following mods:
e-01 MBC,e-manage,ground kit, Typhoon intake, TT.thanks for all replys.
Old Dec 4, 2003 | 09:05 PM
jump23's Avatar
my 2 cents:
I was not able to get the forge bov to stop the fluttering whoosh. It has worked fine for some people so it's possible it will work for you. But I tried every spring and shim combination and it would still flutter.
I'm not sure if it's just the sound or the valve itlself opening and closing to create the flutter. The car did not seem to have any problems idling or anwhere else but I just did not like the "fluttering whoosh" so I kept the stock BOV for now.
Some of the other BOV's are now coming out with recirculating adapters for the Evo. The one I am considering is GReddy Type-S Evo Kit.
Old Dec 4, 2003 | 09:10 PM
Foote's Avatar
GReddy Type S is very good I have that as well as the HKS RS intake sounds great and preforms good no problems so far.
Old Dec 8, 2003 | 04:45 AM
evoego's Avatar
Registered User
thanks guys. Ill give it a try ans see whats up.
Old Jan 14, 2004 | 10:45 AM
treffner's Avatar
I emailed Forge about mine and they said that with stock boost you sould use the yellow spring by itself, with no shims and add shims accordingly if boost is raised.
Old May 4, 2004 | 08:44 PM
mitsuorder's Avatar
I just purchased one, yellow spring has been used effectively by previous owner, what spring/washer combo should I use to hold a good 20.5-21 psi?
Old May 8, 2004 | 09:10 PM
Bom's Evo's Avatar
blue spring here. 19psi.
Old May 9, 2004 | 01:16 PM
mitsuorder's Avatar
ok, I just installed the valve this morning with the yellow spring and my boost won't move past 19psi no matter what I do with my mbc, just saw that Bom's Evo uses the blue spring for 19psi, who here is running around 20.5-21psi and what spring/washer combo are you using with the forge vavle?
Old May 9, 2004 | 05:09 PM
Bom's Evo's Avatar
i've ran 24psi with the blue spring as well.
Egt's too high soo i didn't like it. (1500F) even though its not bad.
Old May 9, 2004 | 05:16 PM
mitsuorder's Avatar
you brave man Bom thank you for the advice
