Evo 8 mr Speedo\Odometer problem
Old Jan 1, 2011 | 12:30 PM
Alienbar's Avatar
Having problems with my speedo\odometer, temperature needle is at H (at top) and the fuel gauge is showing full tank (top) even though the fuel tank is not full and the car is cold. The temperature needle starts in the middle when i turn on the ignition, and as the car gets warm it moves to top (should stop in middle, but since it starts in middle then it goes half way up and stops at the top).
When i turn the ignition on, both the gauges (temp and fuel) shows correct for about 1 sec and then booom at the top . When turn the ignition off it drops to bottom as usually.
Anyone know what the problm might be or how i can fix it ?? Thanks
Old Feb 4, 2011 | 10:21 AM
Evolution84's Avatar
seems like a grounding problem.
try grounding the cluster from another location.
twisty
Jan 7, 2017 12:16 PM
imike92
Lancer Troubleshooting
Jun 4, 2013 09:00 PM
Kendogg
Apr 16, 2012 09:59 AM
iliketoparty
Mar 29, 2012 05:34 PM
Noize
29
May 20, 2005 12:00 AM
