Water temp gauge not reading properly - bad sensor?
Old Jan 28, 2012 | 03:31 PM
iliketoparty's Avatar
I just got my car back after 6 days and now the water temperature gauge isn't reading normally. Before, the needle sat a bit under the half way mark. Now the needle is barely over the lowest line. When I come to a stop the needle will drop slightly and if I give the car gas it will raise a tiny bit and then drop back down. Any ideas?
Thanks!!
Old Jan 29, 2012 | 08:55 AM
I'm starting to think that maybe the 6 days of my car sitting the thermostat got stuck open, causing the car to under heat. Gonna pick up a new one soon and see what happens. Any insight??
Old Jan 29, 2012 | 10:43 AM
Gordian79's Avatar
Stuck thermostat is the problem.I had same issue temp would go down when I got on highway.
Old Jan 29, 2012 | 02:09 PM
I just pulled the thermostat out and tested it by putting into a pot of water and boiling it. The thermostat opened while it was in the water and then started closing when I pulled it out of the water. It's gotta be a bad sensor, right? Or perhaps by some miracle the thermostat actually was stuck and dropping it into the boiling water loosened it back up again. I'm gonna put it back together and after the silicone gasket dries I'll take it around the block and see what happens.
Any more help is appreciated. Thanks!
Old Jan 30, 2012 | 06:05 AM
bump
Old Jan 30, 2012 | 04:51 PM
Does anyone know what the water temp sensor should read when a voltmeter is attached? Gonna try and run a diagnostic tonight or tomorrow. Thanks
Old Jan 31, 2012 | 08:38 AM
Anything on voltage or resistance for the CTS?
Old Mar 17, 2012 | 10:44 AM
Beebo05's Avatar
My water temp guage has been spiking and dropping and i finally replaced the thermostat. the old t-stat had tiny cracks on the core (or whatever you call the piece inside of the spring) now the problem is 100% fixed!
Old Mar 29, 2012 | 01:51 PM
tripper's Avatar
Did you figure this out?
Old Mar 29, 2012 | 05:34 PM
hachansoo0413's Avatar
I have the same problem.
Maybe time to change all gauges? lol
SavageEvo9mr
Apr 24, 2017 06:00 PM
Jmills
Dec 26, 2015 08:25 AM
Wapoosh
Jun 29, 2015 02:20 PM
imike92
Lancer Troubleshooting
Jun 4, 2013 09:00 PM
Kendogg
Apr 16, 2012 09:59 AM
