60k/water pump diy
Old Dec 27, 2011 | 07:23 AM
thedru13's Avatar
60k/water pump diy
anyone Have a good write up on doing the full 60k Service part numbers and all I want to do the water pump and the timing belt at 58500 now thanks
Old Dec 27, 2011 | 07:28 AM
grillpt's Avatar
You can order the whole timing kit from Mitsubishiparts.net, come with everything you need minus the tensioner tool. Search under the how-to, there must be a thread on it.
Old Dec 27, 2011 | 07:46 AM
thedru13's Avatar
found a few kits have been having a hard time finding a good write up been searching can't really find much
Old Dec 27, 2011 | 07:56 AM
grillpt's Avatar
I not really sure about the write-up.. As far as kits go, the one I suggested is a very good deal, that's the one I used.
Old Dec 27, 2011 | 08:03 AM
thedru13's Avatar
did you go with the upgraded belt or just OEM
Old Dec 27, 2011 | 08:28 AM
U.P. Evo8's Avatar
This doesn't include the water pump, but will get you in there. Good write up, with pix...
https://www.evolutionm.net/forums/ev...placement.html
Old Dec 27, 2011 | 08:36 AM
thedru13's Avatar
thanks will check this out at home images are blocked at work
Old Dec 27, 2011 | 08:55 AM
grillpt's Avatar
Just oe. I didn't see the need to go to the gates.
lghtngyello03
Mar 19, 2016 04:25 PM
yenny
Aug 27, 2012 05:41 PM
WORD
Dec 3, 2010 07:51 AM
fitbikedominick
Mar 29, 2009 03:06 PM
Darius@AMS
Nov 12, 2007 09:04 AM
