Profec E-01 install help.
Old Feb 17, 2004 | 10:59 PM
Midnight EVO's Avatar
For Greddy Profec E-01
Does anyone know where to connect the 4 independent wires that go on the ECU.
There is red wire(power), brown wire(rpm sensor), green wire(ground), and yellow wire(optional).
Can anyone tell me where these wires go on the ECU? Also, what is the optional wire for? I don't want to mess up the computer by connecting the wrong wires. Please help.
Thanks
Old Feb 17, 2004 | 11:07 PM
If an EVO ECU diagram is available, that would help a lot. Thanks again.
Old Feb 18, 2004 | 04:39 PM
JeffWels's Avatar
the optional wire is not used unless you want to run a warning indicator (i have no clue how to do this on the evo) anyway the other 3 are just power, ground and rpm. I will find the ecu diagram and let you know where they go in a sec, i'm currently at work
I'd recommend an ecu extention harness for the install of this and any other electronic that needs spliced into the ecu.
Jeff
Old Feb 19, 2004 | 12:49 AM
thanks Jeff for the help. Please post the diagram when you get a chance. Thank you so much.
Old Feb 19, 2004 | 09:42 AM
JeffWels's Avatar
Power is pin 25
Ground is pin 26
RPM is pin 58
What you could also do is wire your power and ground into another place on the car. Such as the radio. I just did it into my ecu extention harness because I was installing the emanage at the same time.
Hope this helps
Jeff
Old Feb 19, 2004 | 03:03 PM
Thanks so much Jeff. This help a lot. Thanks again
Old Jun 22, 2011 | 07:11 PM
j_barcarse's Avatar
Question
I'm missing the pressure sensor for this, can this still be installed without it??
Ryan4dc
Oct 11, 2013 03:08 AM
ParanoidBebop
Dec 20, 2012 04:47 PM
lapulapu
Sep 9, 2008 05:52 PM
DrivenToThrill
Jun 9, 2008 03:11 PM
Evo Tengoku
May 23, 2007 06:05 PM
