ARP head stud install,no cam removal
Old Sep 18, 2005 | 03:21 PM
  #46
dsevo's Avatar
never mind, that was a stupid question. Forgive my denseness.
Old Sep 23, 2006 | 09:12 AM
  #47
vwjeff's Avatar
Originally Posted by BJai02
I am bring this thread back to live!
I was going to do the head studs this weekend along with my camshafts; however, I might not do it just because it could be true that I should not touch it if it ain't broke. I am still debating...
I am reading the service manual and find that using the stock headstuds, I should torque it to 58 ft-lb in this sequence:
8-6-1-3-9
10-4-2-5-7
Then, loosen them all again in a reverse order. And finally re-tighten the loosened bolts to 15 ft-lb in the above sequence again.
What's up with that? I guess it doesn't apply to us who is using this one-bolt-at-a-time method huh?
Why in the F would you start from the middle, and work your way out
When you are removing a cylinder head you always start from the outside and work your way in.
I think the seqence above is the right way... start at 10 and work your way to 1.
Old Sep 23, 2006 | 02:02 PM
  #48
gsrboi80's Avatar
Im gonna do studs soon too but I dont like taking chances Heads coming off. New power enterprise head gasket and cams. Might even get the head machined (mabey not)
Old Nov 25, 2006 | 08:45 PM
  #49
BaLListic_EVO's Avatar
as a revision to this writeup i noticed the nuts where actually a 1/2 inch socket not a 13 mm as previously stated..... the 13mm would work but the nut is actually a 1/2 inch on your new head studs.....
Old May 31, 2007 | 01:21 PM
  #50
bsander23's Avatar
more power equalls head lift, these bolts result in no head lift.
Old May 31, 2007 | 03:01 PM
  #51
upstatescevo's Avatar
just got mine for 89.99 shipped but im doing the headgasket and the timing belt while at it
Old May 31, 2007 | 03:11 PM
  #52
Speed Corps's Avatar
Former Vendor
I don't have any instructions from a set of ARP's sitting around anymore, but doesnt the instructions have the torque values in them?
Old Jul 31, 2007 | 08:53 PM
  #53
chadditty's Avatar
changing head gasket
what are the steps to taking of the head on my 2005 evo8 , you want to mark the belt and stuff to not mess up the timing when putting it back together?
Old May 3, 2008 | 12:56 PM
  #54
MrEvo2nv's Avatar
umm i heard you should do one head stud at a time , cause if u do all at once u risk breaking the seal on the head and getting fluid between the head gasket and head which i heard can lead to premature head gasket failure.
Old May 3, 2008 | 01:34 PM
  #55
CBRD's Avatar
we never do them one at a time... we always pull the head and use a new gasket.
cb
Old Jun 5, 2008 | 03:47 PM
  #56
EvoKnievo's Avatar
cb
also known as the "CORRECT WAY"
Old Jun 18, 2008 | 11:33 PM
  #57
krazirob's Avatar
one question for me........to better ensure there isnt alot of oil in the holes so as to effect how tight one stud is from another....can i just carefully stick some qtips down in there to soak up all the oil and then put the studs in......
i know that qtips sometimes leave a lint behind so i didnt know it that would cause it to be a no no.......?
Old Jul 8, 2008 | 06:42 PM
  #58
lemmonhead's Avatar
dont use q-tips you use to clean your ears. They have specially electronic ones that wont leave the cotton stuff behind.
Old Jul 8, 2008 | 06:59 PM
  #59
krazirob's Avatar
yeah i did this headstud install kinda the same like described but used a technique advised by a mitsu tech......
untorqued all of them and then did it one by one from the inside to the outside......hitting 31 psi and no headlift......
but im doing a rebuild soon anyways so it really didnt matter to me.......lol
Old Jul 9, 2008 | 02:34 AM
  #60
Yamahar1's Avatar
Did my head stud install went really will...now have a 1000 miles on them and no problems with 27 psi
