Fitting a whole QT in transfer case
Old Apr 28, 2014 | 06:23 PM
rcheung's Avatar
Originally Posted by kaj
If they left it in, they kinda deserve it. Should have known better or left the work to someone who did.
A good number of evo x tcs came overfilled from the factory and some dealers got used them coming in and exchanging them under warranty.
Old Apr 28, 2014 | 08:31 PM
kaj's Avatar
kaj
I keep hearing of lots of weird, unpleasant defects for the X. WTF was Mitsubishi doing?
Old Apr 30, 2014 | 05:01 AM
gsrboi80's Avatar
go ahead and do a few like that. let us know how it goes.
A few hahahaha been doing it for more than 8 years now there chief.
Never had an issue EVER. Never Will
Old Apr 30, 2014 | 08:55 AM
cmiller10's Avatar
http://www.jackstransmissions.com/pages/t-case-filling
Old Apr 30, 2014 | 09:11 AM
gsrboi80's Avatar
Yup read it before, it still makes me laugh Useless
Old Apr 30, 2014 | 10:14 AM
kaj's Avatar
kaj
To each their own. Chief? Anyway, I'm sure it's a very low percentage of failures. I prefer 0%, but that's just me.
If you know better than the people that build these, see failure, and base technique on experience, then feel free to continue. No harm to any of us. I'm sure there's lots of stuff I do that is more than I need LOL
Old Apr 30, 2014 | 01:30 PM
cmiller10's Avatar
im glad you said that cause I was gonna try it.lol the way in the car not out. I was told the tcase wont hold fluid out of the car.
Old Apr 30, 2014 | 08:08 PM
rcheung's Avatar
I also filled it through the fill hole. I had an evo 8 for 7 years changing the fluid every 5k miles. When it was time to change it again fluid would start trickling down so It was definitely full. In my X, the rear diff also fills fine through the fill hole but the transfer case does not. It has an annoying way of making you think its full, start trickling out but is nowhere near the approximately 1 quart its suppose to take. You have to stop and start several times. I will try the jacks transmission method on my next change since that would be a surefire way the transfer case gets filled with the proper amount of fluid.
Old Apr 30, 2014 | 08:36 PM
kaj's Avatar
kaj
i filled mine, drove around the block, then pulled the fill plug and leveled the car. it took a few seconds, but sure enough it finally started trickling out. it took a while to stop (and makes a huge mess as it drips all over everything ) but finally did. no noise, no issues. drives great.
better save than sorry, i always say. if ONE person has had issues filling via the vill hole, that's enough to keep me from doing it. they is 'spensive!
i filled my rear diff through the fill hole. the diff is very basic inside and not known to catch air bubbles, etc. if in doubt, you can always spin the wheels a bit then recheck to make sure, i suppose.
Old May 7, 2014 | 07:30 PM
freeagent3117's Avatar
Filled my today with this method:
Place the car on 4 jackstands, high and level.
Drain T-case.
Fill T-case through fill port.
Start car and place into second gear.
SLOWLY let the clutch out and SLOWLY get the car to about 20 MPH.
Shut car off.
Re-fill T-case.
Repeat 3-4 times until full.
Remove jackstands.
Old May 7, 2014 | 07:36 PM
Hoojan's Avatar
I will be filling mine next week following jacks transmission method. Just seems like the best/safest method.
Old May 7, 2014 | 08:35 PM
kaj's Avatar
kaj
Exactly. No cars in gear on jack stands, no guessing, etc.
Simple.
Old Jun 25, 2014 | 03:27 PM
Jetech38's Avatar
This may help you: http://www.jackstransmissions.com/pages/t-case-filling
I recently serviced my TC using this how to. There is no reason to believe that doing it this way is dangerous, especially given that filling it through the fill hole is unreliable at best.
Here's a pic of the fitting I put together with bits from the plumbing department at Lowe's:
Thread the fitting into the drain hole and hook up the barbed end to a fluid pump. The 3/8" NPT isn't a perfect fit, but it's good enough for fluid to stay in. Be quick when you remove the fitting though, it can get messy.
Old Jun 25, 2014 | 03:46 PM
kaj's Avatar
kaj
The NPT will leak a little, mostly because it's hard to get the fitting tightened down (it hits the case). So be ready for a little cleanup during the fill as well.
jesekj00
Feb 11, 2016 11:29 PM
AMTrombley0924
Aug 26, 2014 04:51 PM
yenny
21
Sep 12, 2012 11:28 AM
ElectricBlueIX
Jan 16, 2010 03:47 AM
Ludz
Apr 2, 2003 12:42 AM
