Help!, Walbro 255lph fuel pump install
Old May 17, 2004 | 03:36 PM
silvrevo's Avatar
Hello,
Im just having a shop install my fuel pump, walbro 255lph #gss-342, and the tech called me and said the inlet and outlets are on different ends that they need to be on. I called the place where i purchased the pump and they said it was the correct part number.
So is there any trick to installing this, or did I get a mystery pump?
Any quick helpful advise would be GREAT!!!
Thanks.
Old May 17, 2004 | 03:42 PM
jsprat7's Avatar
evomoto.com has a tech site where it shows you how to install walbro fuel pump.
Old May 17, 2004 | 03:43 PM
jj_008's Avatar
Make sure it is a 342. A 341 looks exactly the same but the lower port does not lay on the same axis as the top port. I know this from experience. The part number is stamp on the pump itself.
Old May 17, 2004 | 08:08 PM
M3lachsilber's Avatar
choad
Moved to How To's and Requests..
Old May 17, 2004 | 08:12 PM
metaphysical's Avatar
Registered User
It an easy install. Should be able to pop the old pump out and put the new one in.
Old May 17, 2004 | 08:25 PM
EVOag's Avatar
Registered User
ahahhah
I just did this damn install and didnt read the fu_king pump
I smell like gas...easy install except...
getting that stupid metal ring...damn...
Old May 18, 2004 | 08:15 AM
silvrevo's Avatar
Ok,,,, package says 342,,,,,,,,,,, pump stamp say 341!!!!!!
Simply mispackaged.
You can close this if you like. Thanks
Old Oct 11, 2004 | 02:05 PM
sleet's Avatar
I just had this SAME exact problem, they sent me a 341 and the bottom port does not line up at all and the damn filter gets in the way.
Old Oct 11, 2004 | 02:10 PM
digitaltekniq's Avatar
I did mine yesterday - took me 20 minutes. The trick is to remove all the hoses from the barbs and rotate the ring around about half a turn. Remove the whole assembly from the passenger side of the car by turning it anti-clockwise.
Old Dec 27, 2004 | 06:21 PM
herbal77's Avatar
how does the car drive with the Walbro 255 , but not tuned
Old Dec 27, 2004 | 07:40 PM
Jakeg97's Avatar
drives the same , but the car will run rich
http://www.evomoto.com/tech_info.php...3_13&tech_id=9
Old Dec 27, 2004 | 07:41 PM
ThEHiTMaN's Avatar
"20 mins" So a first timer could do this in 20 min flat? I am depating on if i want to do it or not....
Old Dec 27, 2004 | 07:43 PM
34Turbo's Avatar
Talking
Telling me... Nobody told me I was sposed to keep the tank empty... Half the driveway was covered in gasoline and my buddy kept on smoking 5 feet from it... It was a fun night...
Old Dec 27, 2004 | 07:44 PM
tke_413's Avatar
It's pretty easy if you know what you're doing. If you don't....HERE YA GO!!!!
Old Dec 27, 2004 | 07:50 PM
ThEHiTMaN's Avatar
That looks like a little bit more then 20min of work.... I just installed an MR DV tonight and it took me about 30min cause the damn radiator hose is in the way.
