How to bleed your brakes
Old Jun 6, 2007 | 09:36 PM
  #46
trinydex's Avatar
uhm... if you're not using the powerbleeder then just keep topping off. you really want a power bleeder though. don't suck it out cuz it'll suck air in when it gets low.
Old Jun 6, 2007 | 10:49 PM
  #47
timmiii's Avatar
Alright, thanks man! Is there anything else I should keep in mind which the how-to from JOE250 didn't mention?
Old Jun 17, 2007 | 11:54 AM
  #48
supersupra's Avatar
yes, after you finish the job and drive around, come back and refill the fluid.
Old Jun 18, 2007 | 04:16 AM
  #49
Evo666's Avatar
I have the motive powerbleeder and it's fun using it every time.
Love how much time you save instead of having someone pump the brakes.
I also went to the local hardware store and picked up some clear tubing so i can see the color change.
Old Jun 30, 2007 | 09:40 AM
  #50
Thegame's Avatar
Wow, I should have printed this out for my local Mitsubishi service department yesterday! They tried to send me on my way with a brake pedal that hit the floor! It took about five guys and multiple attemtps to bleed my brakes!
Old Jul 6, 2007 | 05:01 PM
  #51
MitsuJoe's Avatar
hope they didn't charge you! This is in the service manual!!
Old Jul 6, 2007 | 05:21 PM
  #52
Thegame's Avatar
No it was under warranty! No wonder they don't like to honor warranty work. They don't know how to do them!
Old Aug 20, 2007 | 06:46 AM
  #53
EVO8LTW's Avatar
My 04 RS has the original brake fluid with about 10K miles. In preparation for the first time on the track with this car, I'm going to replace the fluid with high temp fluid. Does anyone know how much fluid you have to bleed out of the right rear before you've got new fluid coming through? I'm assuming that the old fluid will be clean and that I won't be able to tell. I'll be using a Motive power bleeder. I just don't want to leave any old fluid in there, but I also don't want to use more than 1 can of fluid if I don't need to.
Thanks!
Old Aug 20, 2007 | 08:25 AM
  #54
Evo666's Avatar
I used a clear tube (found at local hardware store) connected to an empty water bottle to see the fluid color change
Old Sep 8, 2007 | 10:56 AM
  #55
boomn29's Avatar
Thanks!
Your answer is earlier up in the thread; about 500ml; perhaps more to be safe.
Old Apr 12, 2008 | 08:50 PM
  #56
krazirob's Avatar
nice man, this helped me alot as my local garage told me to bleed in the wrong order............brake pedal feels really good now. just in time for autox tomorrow.
Old Sep 25, 2008 | 05:32 AM
  #57
kenneth2000's Avatar
Guys, is it the "Import" Motive version that we would purchase for the EVO ? (I have a IX)
http://store.motiveproducts.com/shar...unt2=192496895
Old Apr 9, 2011 | 10:17 PM
  #58
tisiti3's Avatar
Hi there?
Anyone knows? What is bleeding order for RHD?
Ta!
Old Apr 10, 2011 | 04:07 PM
  #59
MitsuJoe's Avatar
Should be Left Rear, Right Front, Right Rear, Left Front
Not that I have done a JDM setup although following the writeup and what makes sense to me this should do it for you.
If you get a Phoneix Bleeder that does reverse bleed it really should not matter for you.
Joe250
Jul 2, 2014 08:05 AM
Talon
11
Feb 24, 2014 05:38 AM
matrho2792
19
Feb 25, 2013 09:03 AM
Joe250
12
May 4, 2009 07:03 AM
Joe250
Oct 24, 2004 07:47 PM
