OIL/Filter CHANGE
Old Jul 28, 2004 | 09:37 AM
EVONation's Avatar
OIL/Filter CHANGE
Anyone have detailed instructions of an oil change and filter change? I have heard it is easy but I have not seen it done yet... Please help
Old Jul 28, 2004 | 07:15 PM
LancerEvoMR's Avatar
Moving to Evo H/T Questions.
Old Jul 28, 2004 | 07:59 PM
EvilBlueEvo8's Avatar
jack up the front of the car with jackstands. slide under the front of the car near the passenger front tire. look up. see the filter? its probably black if its a mitsu filter. the draing plug is right next to it. put a pan under it and loosen it. let it drain. put the plug back with the new crush washer that is supplied with the filter. change the filter with new one after that (make sure you put oil in the new filter and put some on the rubber seal. fill the motor with new oil. drop the car. you're done.
Old Jul 28, 2004 | 10:27 PM
spiderm's Avatar
What is the torque setting on the oil drain bolt?
Thanks.
Old Jul 28, 2004 | 10:44 PM
EvolvedDSM's Avatar
29 ft-lbs
Old Jul 28, 2004 | 11:00 PM
gnulooks's Avatar
I would start the engine and let it warm up a bit. Remove the engine filler oil cap. Remove the drain plug to drain oil. After the oil is drained, put in a drain plug gasket and torque it to 29 +/- 3 ft lbs. Change the oil filter w/ a good quality brand because it must withstand an oil pressure of 261 PSI. Take a rag and wipe the dirty oil off the filter bracket side mounting surface and ensure that the old O-ring has been removed. Apply a small amount of engine oil to the O-ring of the new oil filter. When the oil filter O-ring touches the oil pan flange, tighten the oil filter about 3/4 of a turn (124 in-lb torque). Afterwards, fill the engine with about 4.5 quarts of oil. Start the engine and let it idle for a few minutes. Stop the engine and check the dip stick to make sure the oil is right below the maximum line. Add oil *** needed, it usually end up being about 4.8 quarts total into the engine. Also, check under the car to make sure you don't have any leaks. That should be it for the oil change.
Angles217
Dec 26, 2012 05:48 PM
awdturboscott
Nov 29, 2012 08:48 AM
WEVO
13
Mar 15, 2006 07:25 PM
limey
Mar 4, 2003 10:37 PM
pearlwhiteoz
19
Sep 27, 2002 08:58 AM
