How-to: Color match or brighten gauge and interior lights
I'm not sure what you're looking for? If you need the smaller bulb, just go to the dealer and ask for the black base one. The blue base is the larger one. I don't know the exact sizes if are looking for a different vendor?
the blub behind my water temp, fuel and Lancer gauge broke, do I need the smaller or the larger bulb from the dealer for replacement?
Bolsen or anyone, on this picture you provided, http://bolsen.homeip.net/evo/Images/lights/DSC05778.JPG
can you do a quick arrow of which bulb is for which section on the gauge?
thanks!
thanks!
OEM part numbers:
MR444536 - turn signal lamps and warning lamps - There are 18 of these
MN134600 - LCD - There is only 1 of these
MN134599 - speedo/tach - There are 3 of these
(MN134599 has changed to MR444537 b/c Mitsu changed manufacturers.)
i'm sorry, but i looked everywhere, and i've only come to this conclusion...
the gauge/speedometer bulbs are a size t1.5 and/or 74. however, i know that there are 4 bulbs, and one of the bulbs is a lot smaller than the others. what size is that small bulb? i need to get my right side bulb switched out, with fuel gauge and temp. however, i will be applying this mod and cutting off all the condoms...
please help.
please help.
trinydex
141
May 18, 2018 09:34 AM
bolsen
30
Aug 3, 2010 04:11 PM
