no ignition after install
Old Dec 14, 2007 | 11:28 AM
evoxsi's Avatar
me and my bro just got done putting my engine back in after taking it out for to install a new clutch, cams, valvesprings, and a few other goodies. none had to do with the ignition so after a double check of the connections we try and start and nothing happend after 5 cranks. so we recheck all fluid levels, connections, and didnt c anything so we tested for spark. there is none. the engine cranks and is getting fuel but no spark. any help would b great cause right now i dont have time to check everything since it is that time of year we are very busy. thanks for any help
Old Dec 14, 2007 | 11:38 AM
sabastian458's Avatar
Check your oil sending unit and all of your wiring harness again. Then recheck a second time. Then check your crank sensor
Old Dec 15, 2007 | 05:52 AM
evoxsi's Avatar
im pretty confident that the crank senor is in right but after searching some threads i know i didnt line up the cam angle sensor, i just bolted it in. im going to check it today but does anyone know if this would cause the ignition not to work?
Old Dec 15, 2007 | 06:08 AM
smokedmustang's Avatar
Look up one of my threads on this, same thing happened to me. The mechanics "Pinched in half" one of the wires (not sure which one, but it is down low on the timing belt side) when they installed my stroker motor. they resoldered that broken wire, and all was great again- EASY fix. I will see if I can find my thread, and post that link. That is your problem, I bet money on it.
Old Dec 15, 2007 | 09:32 AM
evoxsi's Avatar
ill check it, thanks for the help
Old Dec 15, 2007 | 05:15 PM
evoxsi's Avatar
well i am an idiot, i saw after taking the timing belt cover off that i put the cas on backwards. so i fixed that and ill put the rest back together tomarrow.
Old Dec 16, 2007 | 12:08 PM
evoxsi's Avatar
Help
ok everything is timed and cas sensors are right. now it seems the timing belt is loosing tension when we hand crank it the tension piston goes down is this normal or this a bad tensioner.
Old Dec 16, 2007 | 12:26 PM
evoxsi's Avatar
bump
Old Dec 30, 2007 | 11:04 AM
Evoovasti's Avatar
did the ignition get wet at anytime cause that would do it.
Old Jan 10, 2008 | 01:49 PM
evoxsi's Avatar
figured i would update. we found out after renting an OBDII scan tool that i was throwing a crank angle sensor code. so we tore it down for the 4th time and saw that the sensor plate that runs through the cas was bent on one side. so when it would pass through the sensor it would take off some material which in turn ruined the senor. well we ordered a new one and with the holidays it took an extra week to get it. put it in and started first try and has ran great since. pulls like a ****, i just wish i had a bigger turbo to use these 280s more. im shifting at 7 and i can still feel it pulling.
Old Jan 11, 2008 | 12:08 AM
Jameson_IXMR's Avatar
Good job on the troubleshooting!
billj76
Nov 21, 2016 10:00 AM
ezzey
Jul 19, 2016 04:48 PM
dillons13
Sep 2, 2015 06:25 AM
Paulevo9
Aug 15, 2015 09:02 AM
Johnboy1065
22
Sep 17, 2005 12:36 PM
