Homemade, high quality endlinks guide
Old Feb 17, 2014 | 06:58 PM
  #31
jason42003's Avatar
Yeah I need both in the rear, I'm still running the stock ones, and I got whitelines in the front. But I can't really find anyone that sells the whiteline rears and these look just as good quality at a cheaper price.
Old Feb 18, 2014 | 07:31 AM
  #32
donour's Avatar
Originally Posted by jason42003
So since you are still here just to confirm, for the rear endlinks I just need the 4" threaded pieces and 2 lh thread male ends (2458k142) and 2 rh thread male ends (2458k141) and the various bolts and washers correct?
Yep. For reach rear you need one LH rod end, one RH rod end, one threaded rod, and the bolts/washers.
d
Old Feb 18, 2014 | 08:13 PM
  #33
Boostin_hard's Avatar
nice! added to my project list
Old Apr 5, 2014 | 02:13 AM
  #34
charlie.tunah's Avatar
Are any of you guys using these with cusco plates? Im noticing that Im going to have to run some fairly thick bushing sleeves to space the endlink from the bar so that I am able to reach the other holes. I don't have any experience with any other endlinks for the evo, so Im not really sure what the expect for articulation.
How long is too long for the sleeve? Can I get away with 1/2" or 3/4"?
Old Sep 9, 2017 | 01:27 PM
  #35
TariqEvo's Avatar
I know im reviving an old thread but id like to know if there are better material options since we are now in 2017.
and maybe if the pricing could be updated that would be great.. also some reviews of people who used this?
Old Sep 10, 2017 | 11:12 AM
  #36
donour's Avatar
+1
If somebody sends me info I will update the original link.
d
Old Jan 17, 2018 | 01:56 AM
  #37
Redbud23's Avatar
Veteran: Marine Corp
Just found this and I am purchasing all the parts now. Any issues from the people who have done this? Any installation issues?
Old Jan 17, 2018 | 04:18 AM
  #38
Redbud23's Avatar
Everything ordered I cannot wait to do this HOW TO!!!!
Old Aug 16, 2022 | 08:49 PM
  #39
silverflyer's Avatar
The OEM rear end link length seems to be around 6" and these measure around 6-1/2" minimum length. Does anyone that have used these in the past know if the extra 1/2" length going to cause clearance issues in the rear? The rod end thread length is 1-1/4" and the connecting rod thread length is 1". I ordered Donour's parts list and assembled the full set of end links, but my car is not currently together enough to check the clearances.
Old Aug 18, 2022 | 08:00 AM
  #40
donour's Avatar
*stretch* Waking up for my semi-annual posting.
I've never seen clearance issues on the CT9A chassis. The assumption here is that you're lowering the car, so you'd want to extend them some to keep the bar angle the same as stock (or closer to it anyway). If you're _raising_ the car above stock ride height, you might want to select a different aluminum rod length.
d
Old Aug 19, 2022 | 01:47 PM
  #41
RobbieOh's Avatar
5 Year Member
Dang these look awesome! Now I want to make them for my X, just have to figure if what differences there are.
Old Aug 20, 2022 | 12:57 PM
  #42
d
Thanks for the replay Donour! It's great to see you're still on here all these years! My setup is the stock Bilstein shocks and Gt Worx/Racecomp Engineering lowering springs. Only 0.59" drop in the rear and 0.79" in the front. I don't think I will have any issues with the slight increase in end link length. I will update you guys when I get the end links installed.
Old Aug 20, 2022 | 02:56 PM
  #43
donour's Avatar
Heh. Nobody is more surprised than me.
FWIW: My original parts are still in service in 2022. The car is NOT garage kept and at this point they have been installed for 15 years.
Old Jun 5, 2024 | 09:27 AM
  #44
RobbieOh's Avatar
5 Year Member
Bump for anyone coming here looking to do this to their X: I've been working on these for the rear on my Evo 10. Right off the bat, I went with the 3" connecting rods, instead of the 4". With the ball joint rod ends screwed all the way in, they match the oem length endlinks, thus if you want to make them shorter, 2.75" connecting rod, might be better. Also, I had to order 2.5" screw/bolts and a 0.5" spacer to push them out from the mounting bracket and sway bar. Also, I used the retaining washers on each side of the race ball joint to allow more articulation. Everything else is the same. Will edit with a picture later.
Old Jun 5, 2024 | 09:31 AM
  #45
donour's Avatar
I'll link this post at the top of the thread.
jono2626
Nov 26, 2013 05:49 PM
honda-guy
Mar 16, 2011 02:00 PM
chu
Jul 9, 2009 12:32 PM
Indy Evo
Oct 9, 2008 06:55 PM
sti_this
May 13, 2007 03:25 PM
