AEM Tru Boost Gauge Install
Old Jan 27, 2009 | 09:26 AM
randomevo's Avatar
AEM Tru Boost Gauge Install Guide
Please remember to disconnect your battery before wiring power.
This is a rather simple install but if you don't feel confident in doing it then please don't. You are responsible for your own work
Its also a good idea to temp wire everything before you solder. Test that it works, then solder everything together.
Link to PDF Instructions http://tunertools.com/prodimages/AEM...st_30-4350.pdf
First its a good idea to remove the intake to give you some room to work.
1) Remove stock vacuum lines from stock boost solenoid and wastegate + turbo.
You can not use these lines for the install due to the factory boost pill.
2) Cap off the stock solenoid but do not unplug it.
I used some small vacuum line caps, zip tied and taped up the solenoid.
3) Mount the AEM Boost solenoid.
Link to one possible location.
https://www.evolutionm.net/forums/ev...installed.html
I mounted mine temporary on my battery tray bar. Temp Spot :-(
A good place would be where the stock solenoid is.
With the stock air box its a little tricky to get it on there just right.
Double sided tape and some zip ties should help.
4)
Run vacuum lines.
#2 on the left goes to the waste gate
#3 goes to the turbo.
#1 is capped
5) Feed the long part of the harness, the one with just 2 wires, from the cabin, through the firewall. There is a hole on the passenger side against the firewall.
*TIP* tape the wire to a small pole or something(<< no jokes)) then push it through the hole, once its through, untape it and pull wire through
Once its in the engine bay,I ran this wire across the back of the firewall, around the battery, towards the aem solenoid.
The 2 Brown wires from the solenoid connect to the 2 long wires from the harness.
Polarity does not matter so connect 1 for the red and 1 for the black. Solder tape
6)
T the FPR hose for pressure sensor.
ZIP TIE CONNECTIONS
The clear hose in pic connects to the gauge.
7) Push vacuum line through firewall to the gauge.
8)
Decide on gauge placement and tuck wires
9) Wire the Gauge
I extended both the power and the ground wires.
A)Wire both Red wires to 12v switched power.
I soldered both of them together to my extension wire-then spliced into radio 12v switched.
B)Wire Ground >>> Extened wire then tapped into the Clock for a Ground. You can use Radio ground or a good Bolt Ground.
C)Orange Wire >>>Scramble Boost>>> Did not use, tape it to harness out of the way
D)Gray Wire>>>> Warning Light>>>>> "" "" "" "" ""
10)Connect vacuum line to the back of the gauge. Zip tie for protection.
11) Reconnect battery and check that everything works.
12)
Setup gauge following instructions from AEM manual.
Unl = PSI, BAR, PAS
SCb = Scramble boost settings - Skip
SCr = Scramble boost duration - Skip
SEn = Pressure sensor Select I for Internal- E for optional external sensor
ALA = Boost alarm setting.
gAE = Waste Gate Crack Pressure see below
FUL = Set the full scale for sweeping lights.
Boost setting A= Duty cycle settings
Boost setting B= B duty cycle settings
Boost setting tips
Waste Gate Crack Pressure (gAE)
From the Manual
"Enter the boost pressure at which the waste gate starts to open. The Tru Boost
will keep the boost solenoid open from 1 psi until boost exceeds the selected value.
This value can be adjusted to reduce lead in boost spikes or reduce spool up time."
Most people say set this to 11.5, Which is the stock wastgate spring pressure, then adjust your duty cycle setting until you hit the boost # you want.
This mainly effects spool up and spikes.
Boost Setting A-B / Duty Cycle Settings
Every car will react to this setting differently so there is no "right" value for this number.
I will post different results that people have attained but it is best to self tune this value until you hit the PSI that you want.
This will also change based on the weather. So if it gets cold where you live, or for winter, you may need to lower this setting.
If anyone would like to contribute tips on SPR pressure and Duty Cycle settings, or if you have anything else to contribute please post or msg me and i'll update.
Old Mar 5, 2009 | 03:46 PM
IAmADirtDude's Avatar
all that and you didnt post a picture of the location of the line to the turbo and the line to the wastegate installed.... kinda wierd
Old Mar 12, 2009 | 02:27 PM
idanoclo's Avatar
what about the vac line that came from the bottom of the intake? was that capped off as well? wasnt that vac line coming from the factory boost solenoid? nice write up btw.
Old Mar 12, 2009 | 03:10 PM
drewdq's Avatar
I played around with my TruBoost on the dyno last week, mostly with E85 running as much boost as I could. I ended up having my duty cycle maxed out at 90, and my crack pressure at 2.0 to give me just about 27psi(29-30 in colder weather), tapering to 23psi.
I found that setting the crack pressure higher only caused more boost taper, but it would spike a tad harder at peak load. With my waste gate crack pressure at 10.5, I tapered to about 20psi I think.
Spool up time was not affected much when I lowered the crack pressure either.
So as for setting up this controller, be sure to play with the gAE (crack pressure), rather than just setting it at 10.5-11.
Old Mar 13, 2009 | 11:01 AM
colburn22's Avatar
I hooked mine up last night, and I am only reading 11lbs boost max no matter how i set up my gauge. I hooked up the lines as stated in the directions, and I had no problem figuring out how to change the settings. I have a KN typhoon kit that has a vaccum line coming off of it, that I capped off cause I am not sure where to hook it up (wastegate or turbo side?). The only other line I have is the blow off line that is ran up to the intake nipple on the driverside of intake. I am still on factory turbo setup and IX diverter valve.
Can anyone help me out, based off what I am saying. I have read the few posts on here and it seems like everyone is having the problem trying to figure out the gauge and not really anything about actual problems like this.
Old Mar 13, 2009 | 01:28 PM
biggie5252's Avatar
I'm going to guess that you didn't actually turn the controller on. It comes off out of the box and when it's off the gauge still functions as normal. You either need to press the left button or hold it until it displays a (or right button and b, whichever you prefer) to turn it on.
For the nipple on the intake, you can replace that "sintered muffler", as aem calls it, with a nipple and run that back to the intake. Or cap it and use the muffler
Old Mar 13, 2009 | 02:26 PM
randomevo's Avatar
yes becauase its been cold as ***** here in NY for no reason
yes thats capped off as well.
as for the crack pressure, i keep it there because i'm nervous about it spiking. I'm not boosting that high and still on a pretty much stock tune.
What was the highest spike you got?? and what were you hitting on the dyno with boost that high?
Better pics coming as soon as it gets a little warmer. I know i'm missing pics, this was a write up to help a friend, will add more soon.
Old Mar 13, 2009 | 03:03 PM
Mr. Evo IX's Avatar
Also, The muffler can be removed and you can vent the solenoid back to your intake. It comes with a threaded nipple for this. Just noticed someone else already mentioned it.
Old Mar 26, 2009 | 09:50 PM
N33d4sp33d's Avatar
Is there any similar boost gauge to the AEM ?
Old Apr 22, 2009 | 10:51 AM
randomevo's Avatar
updated with new pics
Old May 6, 2009 | 01:41 AM
EvoBullet06's Avatar
This is much better than the previous attempts at explaining the install. Instructions for AEM seem pretty simple except where it says to connect the hose behind the gauge to the manifold. Once I actually get out to my car and do it I will figure it out. Kinda hard to visualize it when I haven't looked. lol Just picked up the Tru-Boost last night. (from myself) cheaper that way. lol
Old May 24, 2009 | 12:24 PM
pwdrtoastman's Avatar
so where do you solder the gray wire too?
Old May 26, 2009 | 02:56 PM
randomevo's Avatar
i didn't use the warning light, don't know who does but i'm guessing it would be soldered to a small led.
placement is up too you, i just taped it out the way. Update instructions as well.
DOn't use clear vacuum line that you see in pics. It's crap, will update pics with new line soon
Old May 26, 2009 | 02:57 PM
randomevo's Avatar
x2 ;-(
Old Jun 6, 2009 | 04:52 PM
have to sell my tru-boost. Too bad, I was ready to install. need the cash
