oil cooler fan install
Old May 20, 2009 | 06:10 PM
  #31
sblvro's Avatar
got it! it is made by Standard Electrical, NY part number HP7310 Alt. B, 36357-321
Old May 21, 2009 | 03:24 PM
  #32
sblvro's Avatar
bumped for update!
Old Sep 3, 2010 | 12:31 PM
  #33
andrewzaragoza's Avatar
Originally Posted by sblvro
an on/off was chosen as I cannot use the fan control module nor the fan motor switch to tap the connections. I used the cigarette lighter (+) wire which is ON when the key is in ACC and tapped the wire going to the switch and from the switch to the 85 end of the relay switch(engine compartment) the 86 end of the relay is connected to ground. the (+) battery power source connects to the 30 end of the relay switch and the 87 connects to the (+) red wire of the fan motor. the black wire of the fan motor connects to ground located near/above the fan.
why can't you use the fan control module?
Old Apr 15, 2016 | 07:25 AM
  #34
KFC-AWD's Avatar
Bringing back an old thread.. just finished this mod last night. :-) Thanks to the OP for the great write up. The fan now comes with a different harness side connector, so I needed a different connector to replace it to fit the HP7310 connector that was suggested. I had to buy this,
Amazon.com: Standard Motor Products HP7320 Connector: Automotive Amazon.com: Standard Motor Products HP7320 Connector: Automotive
HP7320 connector which will then connect to the HP7310. I couldn't find the part # for the connector that comes on the fan. :-)
Old Apr 15, 2016 | 08:02 PM
  #35
sblvro's Avatar
Pretty cool install. I wished I still had my evo 9 MR
Old May 25, 2016 | 12:34 PM
  #36
defibros's Avatar
hi, is there a wiring diagram for this install? Thanks in advance
Old Jun 1, 2016 | 12:04 PM
  #37
KFC-AWD's Avatar
I didn't use a relay, I just hooked the fan negative wire to a switch inside the cabin, and from the switch to the positive terminal of the battery with an inline fuse. The fan can be turned on anytime though, so just make sure you turn it off when you turn off the car. It's hard not to since the fan is pretty loud when the car is off.
Old Sep 7, 2016 | 02:40 AM
  #38
Nimpoc's Avatar
FWIW, here's another install with more wiring description and an alternate 6.5" fan.
https://www.evolutionm.net/forums/ve...torsports.html
Looking at it more, this smaller fan looks like it flows more air for similar power. I'm gonna try it too. I'd love to figure out a good auto temp switch for it. Open to suggestions...
6.5" fan: https://webstore.spalusa.com/content...1_631_SPEC.pdf
5.2" fan: https://webstore.spalusa.com/content...03013_SPEC.pdf
Old Jun 3, 2017 | 03:41 PM
  #39
Teal2nnr's Avatar
I used a 6.5". Put the LED "cooling fan" switch im the glove box.
Old Jul 19, 2017 | 02:45 AM
  #40
Bonnie's Avatar
thanks for your sharing, it's great.
SmurfZilla
Aug 16, 2015 03:50 PM
hiner005
12
Jun 28, 2014 11:32 AM
kpt6
Mar 21, 2014 05:12 PM
rcantu
Mar 15, 2014 12:23 AM
