How to Install greddy Turbo timer
Old Jul 30, 2009 | 04:44 PM
awd_Boost's Avatar
anyone know how to install one of these are they different from all the other ones
Old Aug 19, 2009 | 02:43 PM
awd_Boost's Avatar
♣ttt
Old Sep 20, 2009 | 12:57 PM
v-manracing's Avatar
You can get to english manual online just search. do you have the harness? that would be a lot easier, installed mine in half hour.
Old Sep 20, 2009 | 01:34 PM
mx4life85's Avatar
If you have the harness installation is easy as pie.
First, connect the harness to the ignition plug under your steering wheel column.
Then run the black ground wire and ground it somewhere safe.
I hooked up the RPM wire (forgot which color...) to my ECU but I don't think thats necessary.
Really all you need to hook up is the ground and the harness to the ignition. I don't even have my parking brake wire hooked up...
Old Sep 24, 2009 | 02:52 PM
FenixTX717's Avatar
I would recommend hooking it up to the parking brake since it's pretty easy anyways. Might as well when you've got half of it ripped out. I believe it's the brown wire that goes to the ebrake.
Old Dec 20, 2009 | 11:04 AM
lude2evo's Avatar
brown wire is def to the ebrake.
Old Dec 23, 2009 | 06:13 AM
nad17vtc's Avatar
do you have a turbo timer? if so you can run all your wires from it, and your illumination one through the dimmer
Old Dec 29, 2009 | 11:28 AM
dolson222's Avatar
Is it any different than installing the HKS tt's or is it the same steps just different wire colors
Old Dec 29, 2009 | 11:37 AM
4G63K's Avatar
Here you go Sir. Have Fun.
http://www.evomoto.com/tech_info.php?tech_id=24
Old Dec 29, 2009 | 12:32 PM
lude2evo's Avatar
i was curious on the rpm signal
Old Dec 29, 2009 | 12:35 PM
lude2evo's Avatar
jus called my tuner and he said i dont need the rpm signal but the ebrake is important
Old Dec 25, 2010 | 02:51 PM
FromStock2Fast8's Avatar
Real easy i did it myself with no experience working on a car , you dont need rpm signal but a Vehicle speed sensor so the car dies right when you try to move with key out
Old Dec 30, 2010 | 12:25 PM
skyway69's Avatar
Originally Posted by 4G63K
i learn to install my tt frm this site too...very usefull
Old Dec 31, 2010 | 10:26 PM
boostless's Avatar
The harness is the best and least intrusive way to install the TT. The harnesses are universal, therefore, using the HKS one will work with GReddy/Apex'i etc.
You don't NEED the RPM wire, but you would be eliminating one of the features by doing so. There's a setting that automatically increases the time based on one of two rpm levels, therefore, setting the appropriate count down time.
The poster that didn't hook up the ebrake wire, yikes, that one is the easiest, and can be done in 5-10min from start to finish
Old Feb 4, 2011 | 07:46 AM
longhornman's Avatar
My buddy tried to install with a harness and he screwed it up. When he call me i had a extra harness and i got him fixed up in an hour. I would recomend if you are going to install a turbo timer get a harness to help you out. So much easier.
smurf34
Sep 7, 2013 11:03 AM
EriCS
16
Apr 25, 2012 09:02 PM
EVOKRAZY8
Oct 11, 2010 10:20 AM
llno24
Jan 19, 2010 11:59 PM
MR.06MR
Jun 30, 2009 02:32 PM
