Hid install help
Old Aug 22, 2009 | 10:17 AM
LGrady31's Avatar
Exclamation Hid install help
I am stall my my HID kit on my 03 evo 8 and i am confused with the stock hid setup. i have the bulbs in and the wire running from the bulb to the ballat but then i thought you ran the wire from the ballat to the stock low beam plug in. well the plug in's are the same. what am i doing wrong.. any help will be appreciated.. thanks
Old Aug 23, 2009 | 03:00 PM
MRWong's Avatar
Are you replacing the stock hids with a new set of oem ballasts and bulbs?
Old Aug 30, 2009 | 01:50 AM
spdracr's Avatar
if u r trying to replace stock hids with aftermarket its not gonna work right lol
Old Sep 10, 2009 | 10:53 PM
hang187's Avatar
why you wanna install hid kit? All 2003 evo comes with hid already, just buy new hid replacement bulb. Bulb size is D2S
Old Sep 10, 2009 | 11:06 PM
Advanap1's Avatar
Pics
Post some pics of what you're doing. Like other people have already said, you can't just plug in your new HID kit harness into the stock bulb harness. Unless you remove your stock HID system and start over with a new kit.
Are you upgrading to a different kelvin rating?
All you would have to do is replace your light bulb and keep the stock ballasts.
Old Sep 18, 2009 | 05:49 PM
Jimevo9PI's Avatar
So It means, I cannot use any aftermarket replacement HID bulb in my EVO 9 MR?
What if I want to replace the stock HID into a higher HID like 8000K? Does it work?
Also how you'll install it, do you have to remove the whole front bumper?
Old Sep 18, 2009 | 07:39 PM
MRWong's Avatar
You can use aftermarket d2s bulbs ...but you do need to remove the lights to replace the bulbs there is no way of gettin behind the light in the car. There is a cap over the bulb with screws and that is directly the chasis or the fender
TxFAkuma
Sep 30, 2015 08:55 AM
Norpothos
Lancer How Tos / Installations
Sep 15, 2015 05:40 AM
LordCthulu
Jun 18, 2015 05:13 PM
JustJeff
Nov 3, 2012 05:55 PM
yorT
Oct 19, 2010 06:57 PM
