Need help asap...headlight problem!!!!
Old Aug 24, 2009 | 08:09 PM
r0me0ne's Avatar
PROBLEM FIXED
Thanks for all the input
DELETE
Old Aug 24, 2009 | 08:26 PM
KnightRyderx2's Avatar
Put everything back to normal with the known blown bulb on the left just as it was 3 years ago when your first installed the kit. Now swap the left ballast with the right side one. If the left side now works then your left side ballast is bad.
Old Aug 24, 2009 | 08:31 PM
r0me0ne's Avatar
the thing is i tried the bulbs on both sides, it works on the right side but not the left, i then changed out the old ballast on the left with the new one, it still didnt work...
i think it is a fuse
Old Aug 24, 2009 | 08:43 PM
So when you hook everythign up on the rigth side everything works? Every combination of light and ballast on the right. Does your kit hook up to only one side or both stock harness?
Old Aug 24, 2009 | 08:48 PM
Sievers's Avatar
It is unlikely but possible the new ballast is defective
I do not believe they are fused individually
Old Aug 24, 2009 | 08:50 PM
I mean when you plug the kit into the stock harness for power and control does it use one stock headlight plug or both?
As for fuses there is only one fuse for the head lights so if it was the fuse your headlights wouldnt work at all. Im thinking you might have burnt up a wire on the side.
Old Aug 30, 2009 | 06:10 PM
r0me0ne's Avatar
Y do u keep bumping???problem is fixed
sEVO IX
Jun 25, 2014 06:51 AM
smoke3d
May 15, 2014 11:49 AM
Jscott
Apr 8, 2014 06:11 AM
CDrinkH2O
Nov 6, 2012 06:50 PM
EVO9WOW
Sep 19, 2011 02:02 AM
