How do u raise the beam of your headlight?
Old Feb 22, 2010 | 01:16 AM
Nomad4g63's Avatar
I feel as tho my headlight set @ the highest level setting is still how the projector beam of light too low, how do i raise it?
Old Feb 22, 2010 | 10:48 AM
Nasty Evolution's Avatar
A 10mm nut you turn on the back side of the headlight, however it will raise the high beam and low beam together unless you unscrew and remove the cable gear from of the adjustors for each beam.
If you the need to adjust the low beam, it's a bit more tricky. The leveling motor is a PITA to get to with the headlight in the car still. Sometimes you can turn the gear on the cable adjustor where you removed it from the hi beam, sometimes you have to try to force the leveling motor to turn by by turning a plastic hex head on the back of the leveling motor.
Just pull your headlight out and you will see what I mean. Unless someone has a pic to post, I don't at the moment.
Old Mar 1, 2010 | 07:52 PM
redhott92's Avatar
im having the same problem, especially since my headlights are smoked
Old Mar 12, 2010 | 02:07 PM
dasmyevo88's Avatar
i dont know if u can explain it better then he did
Old Mar 12, 2010 | 02:10 PM
dac001's Avatar
there is a How to: somewhere....
Old Mar 14, 2010 | 09:35 AM
d0nald's Avatar
https://www.evolutionm.net/forums/ev...adjusting.html
Scroll down to post #5
mtn007
Mar 23, 2026 02:07 PM
Tommyy
12
Nov 3, 2015 05:52 AM
slatermvp
Dec 31, 2010 07:07 PM
sdfontanini
Jan 29, 2008 09:07 AM
QtLancer
24
Dec 5, 2006 12:02 PM
