hks turbo timer help
Old May 24, 2010 | 03:28 PM
timmycat's Avatar
for some reason i cant get my turbo time to display speed, i tryed like 30 times to program it and then i pres the button when im at 30mph like the directions say it just shows 0 mph, also i have a apexi avcr and it to is tapped in to the speed out put wire in the ecu harness. could having both things taped into the same wire be messing things up?
Old May 25, 2010 | 11:22 AM
SwishaSweet's Avatar
your tap on your timer is probible screwed up
Old May 26, 2010 | 10:18 AM
timmycat's Avatar
all the connections look fine ill check them again
Old May 28, 2010 | 07:13 PM
timmycat's Avatar
i just redid the speed out put wire and its doing the same thing
Old Jun 5, 2010 | 10:57 PM
ganda199's Avatar
x 2 on wrong tapping. I'd make sure that it's all correct with other wiring diagram sources. I remember when I was trying to install mine, I pulled up couple of how-to's for evo 9 and found slight differences between online and offline version. Sorry it's been a while since I installed it so can't be much help but I'd look for other diagram sources see if it matches with whatever you followed.
05EV08
May 8, 2016 11:32 AM
MagicManRed
Oct 25, 2011 10:57 PM
David Buschur
60
Aug 31, 2010 06:43 PM
Rob W.
Aug 24, 2006 10:37 AM
cky3396
Apr 12, 2004 11:57 PM
