I just change my tc fluid now leaking
I just got done change it and I see a puddle in my garage. I see some oil under the the front shaft drive line and the front cross bar. All I did was change the fluid. Please help
If you have OEM exhaust, the fill plug is over the exhaust and the heat shield around the exhaust will fill with oil - not good - it could cause a fire. If that is the case you need to pull the shield and remove the oil.
Next time put some plastic over the exhaust.
The first time I filled mine I put too much in and it leaked out the passenger axle seal...making a big smelly mess under the car
I set the fluid to the correct level and the leak went away.
I fill mine from the bottom untill fluid comes out the fill hole, just had to let the stuff drain out the top untill it leveled off and it was all good!
I set the fluid to the correct level and the leak went away.I fill mine from the bottom untill fluid comes out the fill hole, just had to let the stuff drain out the top untill it leveled off and it was all good!
You should have asked the locals, fresh!
You figure it out? As others have said, likely either leftover mess (clean it up, put a paper towel or cardboard down to track if it comes back) or the washer (missing or needs replacement). Sometimes the washer won't come down with the plug but it will come off with the fluids. G/L!
etown09
10
Sep 4, 2012 12:56 PM
