clutch removal and install
Old Mar 24, 2011 | 11:17 AM
Alexl08's Avatar
I rebuilt my whole motor myself in my garage. Put it back in the car trans and t case bolted up already. When I bleed the clutch the retention clip came off for the TOB I took it to someone to pull the trans off. I had enough and knew it was a pita.
Old May 19, 2011 | 10:11 AM
mission664's Avatar
Originally Posted by EvoooB
Something tells me if your too lazy to use the search button, you should probably just pay someone to do your clutch
agree.
Old May 19, 2011 | 10:23 AM
sharkm87's Avatar
mm this was started last sept.. wonder if he's still on his garage floor tryin to do this..
to all you nay sayers.. i've done it twice just me and my brother..outside on the ground...yea its alot of work but its not hard at all....just follow evomoto directions step by step...did that the first time.. the second time didn't need instructions at all.. pretty simple, really just takes muscle
Old May 30, 2011 | 11:27 AM
RA010926's Avatar
i used
http://www.evomoto.com/tech_articles..._article_id=27
and it helped me a lot... probably takes 24 hours to do first time
Old May 31, 2011 | 10:45 AM
RA010926's Avatar
bump
Old Jun 1, 2011 | 12:05 AM
governmule's Avatar
I ended up gettin the job done. Twice now actually after I did the 9 swap. Not as hard as people made it out to be. Just time consuming.
Old Jun 19, 2011 | 08:18 PM
TommiM's Avatar
I have the head off my block doing a rebuild. pretty much removed everything. I have the pistons and rods pulled out, but crank is still in the block. the pulleys and belts are off the front oil pump cover. Just the oil pump cover is on. intake manifold is obvously not there, exhasut manifold, turbo, dp is all off too. Oil cooler off,etc etc.. At this point is it possible to remove the pretty much bare block with the clutch/flywheel assembly still on, and take out the block that way? It looks like the transfer case might get in the way, but was wondering if anyone has thoughts on this. I need to take the block out of the car now and I have enough room to slide it towards the passenger side. Problem is that the tc hugs the block in some parts and you dont have lots of wiggle room.
Old Jun 21, 2011 | 08:01 PM
Joesforspeed's Avatar
You can do it
Old Jun 21, 2011 | 09:35 PM
rider3400's Avatar
if ur askn have a shop do it
Old Jun 22, 2011 | 05:49 PM
governmule's Avatar
The clutch was really easy. You all made it sound hard. Finally finished school at whotech. Gettin a shop started in the northern il area. I've already fabricated a C5 twin turbo vette and an M3. We fabricate all our own stuff including exhaust manifolds.
Old Jun 23, 2011 | 07:41 PM
the mark w's Avatar
the t-case blocks one transmission bolt that i recall. other than that you in theory could pull it apart. only pita thing is the tob because it doesn't always release the easiest.
Old Jun 27, 2011 | 12:14 PM
Alpha1's Avatar
I am sure mine is about to start slipping soon so I am gonna get it done professionally........Its not that I am lazy but ppl spend time and money learning to do this stuff, lets keep em employed lol......and from what I keep hearing its ALOT of work
Old Jun 29, 2011 | 09:15 PM
ElectricBlueIX's Avatar
My clutch just started slipping and I've had it done twice by my friends shop and he always does a great job but this time I'm wanting to do it myself. I've worked on DSM's for years and I know the EVO is a PITA but I'm mechanically inclined and have done quite a few clutch jobs. The benefit of my current clutch setup is that its the Competition twin that converts the car to push type clutch. So it'll be much easier without having to release the TOB. My friend told me he would help me out by doing it 50/50 and charge me basically half if I do half the work...but I feel like I can do it myself. I'm gonna be ordering new discs and TOB this weekend. Then I just have to figure out a time to work on the car. Prolly gonna order new bolts for the pressure plate and flywheel, Clutch fork, etc. this time. The car has about 74k miles on it.
kaczordd123
10
May 7, 2012 10:57 PM
Brsox10288
Mar 9, 2010 12:42 AM
exhaust_note
Aug 11, 2005 09:44 PM
rustyj84
Aug 16, 2004 09:25 PM
ReHeat
Sep 2, 2003 08:56 PM
