Clutch Restrictor Pilll!
Old Apr 18, 2012 | 05:57 PM
kaczordd123's Avatar
Thumbs down Clutch Restrictor Pilll!
so ive removed the pill and the clutch still grabs as high as it did with the pill in there ive bled the clutch multiple times and same thing. Anyone had this happen ?
Old Apr 18, 2012 | 07:51 PM
A769's Avatar
Mine went back to being way up high as well but I don't mind it because rolling out in first doesn't bog like it used to
Old Apr 18, 2012 | 08:09 PM
siceclipse's Avatar
is there a lock nut on the rod behind the clutch pedal going to the master cylinder like most DSMs and Evo 8/9's have on the X?
Old Apr 19, 2012 | 05:46 AM
no its not adjustable
Old Apr 19, 2012 | 06:37 AM
stokEd's Avatar
What clutch are you running?
Old Apr 19, 2012 | 06:46 AM
Kracka's Avatar
The pill won't change engagement....grabbing low would mean the system needs bleeding.
Old Apr 19, 2012 | 01:54 PM
clutch masters stage 3
Old Apr 19, 2012 | 05:51 PM
smason's Avatar
hey I just bought a 2011 evo X and hate the clutch. do u have any recommendations on a new clutch that wiill give me a better launch? I have to rev it high for a quick launch now and sometimes still bogs.
Old Apr 20, 2012 | 05:54 AM
jyamona's Avatar
that's not the clutch causing the bog. either you didn't use the two step or forgot to turn off traction control lol.
Old May 6, 2012 | 07:58 PM
NateDaJew's Avatar
Your clutch will now engage in the same spot unlike all over the place with the pill.
Old May 7, 2012 | 10:57 PM
43%burnt's Avatar
pulled the pill out when i installed the ams master cylinder brace. totally worth the time. no more almost bogging down starting from a stop randomly.
CaptainCrunch
Jan 8, 2016 03:04 PM
sith_killer_99
Dec 29, 2009 06:01 PM
stokEd
Nov 21, 2009 10:32 AM
2StepsAhead
Jun 9, 2006 05:29 PM
exhaust_note
Aug 11, 2005 09:44 PM
