Engine install
Old Oct 29, 2010 | 10:42 AM
solidslo's Avatar
Engine install
Hello i am kind of new in this forum and sorry if i didnt post this in the right theme, but i have a big problem...i mounted engine to my evo and i forgot a little bit of where all the electronics and vacum hoses were installed, if anybody has any pictures of detailed motor mount i would be thankful alot!
Old Oct 29, 2010 | 12:48 PM
EvoVIII808's Avatar
Vac diagram is under the hood, on right side. All the Electrical stuff has colors inside the connectors. Match them up and your all done.
Old Oct 29, 2010 | 10:38 PM
solidslo's Avatar
my entire car is painted on white, and i dont know where to look for vac, but ill find it not that much of a problem..i have a new one, i connected clutch and id doesnt work, it doesnt stiffness, its soft when u push it and pedal stays in, doesnt go back...do u know what the problem could be? thanks for connectors btw
Old Oct 29, 2010 | 11:13 PM
EvoVIII808's Avatar
Sound slike master slave cyl is either bad, or you have air in your clutch line. Need to bleed it and see again. Better if you have 2 people to do this.
Old Oct 29, 2010 | 11:22 PM
solidslo's Avatar
About clutch ill try as u sayed and ill report to you how i did. thnx for pic
Old Oct 30, 2010 | 12:43 AM
EvoVIII808's Avatar
no problem, also make sure you fluid level is full, brake/clutch use the same holder. except for the clutch uses the fluid from the middle.
Old Oct 31, 2010 | 11:50 PM
evopaul's Avatar
I purched a CD on line .."mitsu repair manuel". It really has helped me with alot of issues i have come accross. I bought it from Ebay
Old Nov 1, 2010 | 11:38 AM
solidslo's Avatar
thanks im about to finish my build off, i just didnt know where to put all those vacum hoses hehehehe thanks alot!
Old Nov 2, 2010 | 11:31 AM
solidslo's Avatar
I have more questions i hope im not too annoying
What fluid should i use in my Gearbox? it is 6 speed
and what fluid should i use in differential???
Old Nov 4, 2010 | 12:48 AM
EvoVIII808's Avatar
Th Stock Mitsubishi stuff is good.
Old Nov 4, 2010 | 01:18 AM
solidslo's Avatar
That's the CASTROL TAF-X ?
Old Nov 4, 2010 | 11:38 AM
EvoVIII808's Avatar
http://www.maperformance.com/evo-vii...n-gear-fluids/
Old Nov 6, 2010 | 05:28 PM
solidslo's Avatar
Hello, i have one more question..i have both rear lower arms broken..and i was wondering if anyone has OEM REAR LOWER ARMS for Sale??? they dont have to be new!! I Need them as cheap as possible. Please send me offers on PM
I need them for my Evo 8
Peace number 12 !!!
Old Nov 7, 2010 | 01:18 PM
EvoVIII808's Avatar
Peace number 12 !!!
There is an upgrade to the stock one. Megan ($350), I think White Line also makes them (or maybe it just the bushings). Can Also Try Ebay Can be as low as $55 a piece. Post in the WTB section
Old Nov 7, 2010 | 01:42 PM
solidslo's Avatar
i have no permission to post a thread in that theme...i dont need upgraded, just original and for the lowest price since my budget is going to the end
