ACD Relocation
Old Mar 16, 2011 | 07:43 AM
speedingtwinky's Avatar
Very nice write-up
Old Mar 16, 2011 | 09:22 AM
awdboosted's Avatar
The other thing I would look at is using rubber isolators, just like the factory does. I think this is a great write up too.
Old Mar 18, 2011 | 03:14 PM
joseph143's Avatar
Hey guys thanks for the input.
On evoscan 2.8 in the ecu type drop down change it to acd. Then load the actuators. One says air bleed I think. That's the one for bleeding. Sorry im on my phone not my pc so im not certain.
As for the hose. My car is a DD so I did a temp install to see if it would all work out. I do plan to switch to a professional line later on.
As for corner weights my car is heavier on the ps versus the ds. I have a 2.5 gal meth tank/pump and co2 sprayer tank on the ps. Adding the battery brought them close til I dropped the charcoal chanister now with the pump they should.be close again. I might check when I get back from vacation.
The rubber isolators are a great idea. I will look into doing something like that.
Old Mar 22, 2011 | 06:25 AM
awdboosted's Avatar
As for the hose. My car is a ds so I did a temp install to see if it would all work out. I do plan to switch to a professional line later on.
Check these out
http://www.mcmaster.com/#vibration-isolators/=bjkmm4
Old Mar 23, 2011 | 09:37 PM
joseph143's Avatar
Originally Posted by awdboosted
call me cheap...
my first thought was my stock shifter bushings...
yours would probably work much better though...
Old Mar 27, 2011 | 10:35 AM
Aspen One's Avatar
Nice write up
Old Jul 27, 2011 | 12:06 PM
timmiii's Avatar
Great write up but I was wondering, could one use stainless steel braided lines instead of hardlines?
Old Jul 27, 2011 | 12:26 PM
mdsevo06's Avatar
Who needs snow and gravel mode, just remove all together and save the wieght on both ends.
Old Jul 27, 2011 | 04:22 PM
Ryan.Kauz's Avatar
other then the ability to run a 3 inch intake pipe down into the front bumper the only real benefit it taking the expensive **** pump out of a high risk area. any small animal or large rock oeven a curb could wipe this pump out and cost you a lot of money.
Looks like a pretty damn high risk area to me! Its just as likely to be destroyed in the location photographed as it is in the front. Except it was more protected from the elements up front with the under tray on (salt etc).
Old Jul 28, 2011 | 06:25 AM
mdsevo06's Avatar
^I don't always drink beer, but when I do, I must have a blunt...
Stay thirsty my friend
Old Jan 21, 2012 | 06:42 PM
R/TErnie's Avatar
I need to route the hardline and fittings to the ACD now. I'll work on that this coming week.
I'm trying to decide whether i want a lower CG or a slightly better L-R balance. I think I'm going with option 1
Option 1
Option 2
Old Jan 23, 2012 | 07:02 PM
awdboosted's Avatar
Wow. Very clean. Looks good
Old Jan 30, 2012 | 01:18 PM
dolson222's Avatar
Cool idea but why not put the whole thing in the trunk. That seems to me like just a better balanced (L-R weight) high risk area. Is there somwhere behind the rear diff that it could mount? I havent looked but it would be able to be cooled and protected without having the rear wheels flinging crap at it if its closer to centerline of the car.
Old Jan 30, 2012 | 02:33 PM
R/TErnie's Avatar
I've got a carbon fiber shield for it. Just no pictures yet.
Because improving the CoG is just as important as tire sensitivity. No reason to place it higher than it already sits.
Old Jan 30, 2012 | 03:18 PM
siceclipse's Avatar
looks really good!
