No start issue! maf?
Old Mar 27, 2011 | 05:52 PM
evo8dreamcar's Avatar
Well i have been having this problem for a week now, but just today i might have figured it out. The car wont start it has fuel spark and air. If i Unplug the maf it starts and idles and all that. I didnt try to move it.
Would that mean its the maf sensor?
Anyone in nj around the 08802 area code so i can test theirs out real quick to make sure thats it before i spend more money on it when its not the problem?
Old Mar 27, 2011 | 05:58 PM
And i did a boost leak test.
Old Mar 27, 2011 | 06:42 PM
bump
Old Mar 28, 2011 | 02:05 AM
Anyone?
Old Mar 28, 2011 | 10:57 AM
Noone has idea?
Old Mar 28, 2011 | 02:02 PM
alianum777's Avatar
Might be your MAF, I had a friend had a similar problem with slightly different symptoms. I swapped his MAF with mine and the problem went away. When you unplug it it's probably defaulting to a setting and letting your car run but with it plugged in it might be flooding the plugs or providing some other incorrect reading to prevent the engine from starting. Best bet see if you can swap with a friend rear quick. GL
Old Mar 28, 2011 | 03:11 PM
Finally thank you. I'm gonna try. cause i dont know what else it can be. cleaned injectors, new fuel pump, flushed fuel system, swapped injectors, tried a map sensors only thing i can think of is the maf or fuel pressure regulator. but the maf unplugged kinda makes me think its the maf.
Old Mar 28, 2011 | 04:50 PM
alianum777's Avatar
If it starts with the MAF all disconnected and stuff it shouldn't be the fuel regulator or anything like that I believe. It's sounds like the MAF screwing with settings for a cold start!
alianum777's Avatar
Where are you located?
Old Mar 28, 2011 | 07:59 PM
In warren county nj. i just tried to put the new one i got on and still nothing. but i also didnt mess with it much. im gonna try again tmro and see if it goes.
Old Mar 29, 2011 | 07:04 AM
alianum777's Avatar
are there any codes coming up when you scan the car? Also check out a local forum TSE, Tristateevo.com might be able to get more local help there after you make an intro thread etc.
Old Mar 29, 2011 | 09:31 AM
Thank you. But no codes :/. I wish there was so it was an easy fix
newpassport
Apr 3, 2014 05:04 AM
satanbaby
Jul 8, 2012 10:03 PM
westmc
Nov 7, 2010 02:57 AM
SLW EVO
For Sale - Cars For Sale
15
Jun 11, 2007 01:50 PM
525iT_Feen
West Region
10
Feb 15, 2005 12:49 PM
