Belts!
Old Jun 7, 2011 | 11:09 PM
Tevo9K's Avatar
Belts!
Hai does anybody know the easiest way to replace the engine belts?? and can you name the steps or place a diagram of the break down???
thanks a bunch!!!! =D
Old Jun 7, 2011 | 11:23 PM
katchup's Avatar
which belts are you referring to?
Old Jun 7, 2011 | 11:49 PM
Tevo9K's Avatar
Its the drive belt not the timing belt.. The belt is starting to crack and make squeak noises =(
Old Jun 8, 2011 | 01:43 PM
katchup's Avatar
Its pretty easy, i did it in about 45 mins by myself. Search and there are great how to's on here that i followed.
1)First step is take off the passenger wheel
2)take off splash gaurd
3)get a 1/2" breaker bar and there is a 1/2" square fitting on the tensioner, i cant rem if you tirn it CW or CCW, but youll see when you are down there.
4)Use a screw driver to keep the prybar in place and wedged so you have slack in the belt
5)take belt off, i cut mine to make it easy
6)hardest step, putting it back on, take your time, work from the firewall side to the bumper side(keep the tensioer loose)
7)Once the belt is on remove the screwdriver that it holding the tensioner.
Also i made a quick sketch before i took my belt off so that i could know how to put the new one on. Made it easy!
Hope this helps
hispanicpanic
Apr 18, 2016 12:03 PM
NERO_NOVA
Lancer Tranny/Drivetrain Tech
Nov 21, 2010 01:17 AM
Beluga
Jun 3, 2010 10:17 AM
malonejr2000
14
Oct 7, 2009 03:39 PM
E VOL IX
Jun 4, 2007 05:19 PM
