help!!!tie rods
Old Jun 26, 2011 | 11:09 PM
pinoy6969's Avatar
help!!!tie rods
how would i know if either my inner or outer tie rod is bad,,, thanks for the help
Old Jun 26, 2011 | 11:14 PM
02-Lancer-Es's Avatar
I would explain it but its easier to look up Tie Rod on youtube
Old Jun 26, 2011 | 11:17 PM
warstang27's Avatar
heres how I check it. if you can manually move your outer by hand it needs to be replaced. if you take the outer off and the inner just falls to the ground it needs to be replaced.
below is a link to inner replacement. theres a little washer between it and the rack that locks it in you need to straighten it out to get it loose
https://www.evolutionm.net/forums/ev...-tie-rods.html
Old Jul 5, 2011 | 10:36 AM
toyota4me2's Avatar
If you are in doubt , Then just replace is my moto
Old Jul 6, 2011 | 12:07 PM
1UpMoto's Avatar
Grab the outter tierod where it connects to the hub, and while touching the hub and tierod with one hand have someone shake the wheel back and forth. You should be able to tell if there is play right there.
Old Jul 25, 2011 | 12:38 PM
LsXordie's Avatar
Just tug on the wheel and if it has play. Usually the tie rod ends go out before the Inners.
WillyB1997
Lancer Troubleshooting
Mar 15, 2016 06:30 PM
ihockey1
Jun 23, 2015 08:34 PM
meltdown
10
Dec 15, 2012 05:31 AM
tougetuned
Mid-Atlantic Region
Dec 20, 2009 07:08 AM
silverain
Jun 20, 2008 02:05 PM
