93octane to E-85 easy way?
Old Aug 5, 2011 | 03:23 PM
erald01's Avatar
the passanger side drain bolt, you can feel it by hand and its very easy, just loosen enough to drain then tighten it up...the whole hose thing in your engine bay sounds messy to me..
Old Oct 12, 2011 | 01:53 PM
Rmeister007's Avatar
I hear that when you do this, you shouldn't go hard on the first tank. You should wait until the second tank to WOT. Just what I heard....also, be aware that the low fuel light turns on with 3 more gallons in the tank! So calculate wisely (cuz otherwise you'll leave a lot of remnants of pump fuel in the tank and your car will be running 97 octane instead of 105)!!
Originally Posted by gCASEy200
+1
Old Oct 12, 2011 | 03:17 PM
marcusE's Avatar
I'd say just run it about 20 -27 miles past the Gas light coming on and then fill up.. Thats what it took me to sputter out on e85 switching to 93.
Old Oct 12, 2011 | 11:25 PM
well, going from E85 to pump gas is not the problem (mix them and you're running 95 or so). The problem is going from pump gas back to E85 (mix them and you're running 98 or so and if you're tuned to 105, that could be problematic).
Old Oct 21, 2011 | 03:53 PM
steveyrich's Avatar
I bought a 6' length of fuel hose from the parts store, unhooked the return line and ran the hose to a bucket. I used EvoScan to activate the fuel pump until the tank was almost empty. Don't go too low, the fuel pump(Walbro) made some funny noises trying to draw all that fuel out of there once it got towards the end. I still had plenty enough fuel left to drive to the gas station and fill up on E-85. I wouldn't worry about having a gallon or so left of 93, just fill the car up as far as you can on E-85. Don't go beat on the car on the first tank but you will be fine if you get into some boost. You might be running a tad richer than normal but the octane level should still be high enough for the tune.
I didn't want to use the drain bolt on the fuel tank because I've heard it runs down the side and isn't a straight stream. Also, because of that, I planned on reusing the gas and putting it in my beater, gas ain't cheap!
Old Oct 21, 2011 | 03:54 PM
RazorLab's Avatar
You can do that with the car running, no need for the evoscan way. It will flow out faster as well.
Old Oct 31, 2011 | 06:18 PM
volkevo9's Avatar
You dont want to mix fuels for a tune but you can your not doing a tune.
Jp7
E85 / Ethanol
64
Nov 27, 2017 12:07 PM
PracticalDriver
Oct 25, 2016 12:18 PM
Spec-Ops1
E85 / Ethanol
15
Jul 30, 2015 03:52 PM
xsolowx
15
May 13, 2015 06:21 PM
06MRV8Killer
Southeast Region
Feb 1, 2011 08:51 AM
