Walbro 400LPH Fuel Pump Modification
Old Oct 7, 2011 | 10:12 AM
REV.olution's Avatar
Parts needed:
  1. 10" Clamp
  2. Walboro 400LPH Pump
  3. Install Kit
  4. Wrench Set
  5. Dremel
First here is a close up of both pumps, you can see that they are almost identical in length, but width is where they differ.
So, it's not exactly a step, but prep work includes removing the fuel pump canister and draining it of gas. I'd hate for you to dremel the thing and gas flow constantly.
Just so you don't forget, salvage the black rubber gasket from your stock setup and put it on the new pump.
Now we are ready. You need to dremel the pump's cylindar so the wider base will fit. There are many arguments over what is best, above the first tabs, or under. I didn't want to take the risk, so I used the dremel to the bottom under the clips. Here is a photo:
Before we push the pump in, there's two steps I recommend. First, install the install harness.
Second, put the 10" clamp within the setup.
Now, you are ready to slide the pump in. Make sure you connect the harness to the top of the pump, and arrange the clamp so it is positioned in the middle of the pump.
Torque down the clamp to a moderate level. Not too tight, but tight enough so that the pump will not slip. Once torqued, I choose to weave the excess thread for visuals.
The pump should now be extremly sturdy, and will not slide.
Clip on the filter, and you care finished. Congrats, you have an amazing fuel setup for a cheap price.
FPR's and re-wire setups are not required, but are recommended.
Old Oct 7, 2011 | 10:28 AM
twabtoxer's Avatar
thanks for the write up.... looks very good and easy im sure it does take time and maybe a bit of pain lol. but looks good nonthe less
Old Oct 10, 2011 | 02:54 PM
Upgraded, seal is perfect, no complaints.
Old Oct 15, 2011 | 07:10 AM
GBAILEY472's Avatar
Looks easy, and prove's the point that many said couldn't be done... congrat !
Old Oct 15, 2011 | 07:31 AM
evolutionxtac's Avatar
Why do you use such a large clamp?
Old Oct 15, 2011 | 08:51 AM
drb's Avatar
drb
are you able to use the stock FPR with this fuel pump?
Old Oct 15, 2011 | 09:26 AM
I choose this clamp because I believed it would not only hold onto the pump well but provided a good barrier to protect pump slipping.
You probably can, I just had an aftermarket setup and thought it would be a better safety barrier. I can't promise you anything, you may have to ask an expert
Old Oct 17, 2011 | 07:24 AM
Ev0ikon's Avatar
Stock FPR is actually very good! I would like to hear it if anyone has problem with it on this pump.
Old Oct 17, 2011 | 09:31 AM
Yeah, I can't vouch for it cause I've always had my AEM FPR, I'm sure the stocker can hold up. Nevertheless, adjusting FPR on the fly is always a treat.
Old Oct 18, 2011 | 08:45 PM
drb's Avatar
drb
If there is a problem with the stock FPR with this pump it will likely be that the idle/low load fuel pressure will be too high. If thats the case it's going to make tuning difficult without an aftermarket adjustable FPR to reduce the fuel pressure.
Old Oct 19, 2011 | 06:22 AM
turbotekray's Avatar
Just did mine last night, also did the rewire, while i don't have a fuel pressure gauge in i logged some of my fuel trims at cruise and idle and so far they seemed to remain the same at cruise and idle. (still using the stock fpr) I will let you know if anything changes this afternoon. I am also quite amazed on how quiet this thing operates, cant hear it whatsoever
Old Oct 19, 2011 | 07:22 AM
Ev0ikon's Avatar
I got the same result. Only that right after I replaced the pump I found a cracked weld on my manifold so I didn't get to test. No idle problem to speak of. Will give it hell once I have my stuff welded back up.
Old Oct 19, 2011 | 07:24 AM
Good luck, please report back
Old Oct 19, 2011 | 09:29 AM
drb's Avatar
drb
Thats great information, keep us informed. I just ordered the fuel pump and FPR yesterday but I probably won't use the FPR if I don't need to.
Old Nov 14, 2011 | 10:27 PM
jdm-vr4's Avatar
so any updates on the stock fpr and this pump?
