Any benefit to recirculating a bov?
Old Dec 14, 2011 | 11:07 PM
Dynotech Tuning's Avatar
If your running the Maf you need to. Thats how the Ecu runs properly, and was designed. Im sure there are countless threads about it.
-Brian
Old Dec 15, 2011 | 10:37 PM
korny's Avatar
Originally Posted by PatricksEvilEvo
Very true I liked my 9 bov more than this HKS. But on the other hand the HKS sounds better and vented it sounds ridiculous. SO LOUD
evo9 bov is the best
Old Dec 21, 2011 | 09:53 PM
johnnydemz4G63's Avatar
^^^^^what this guy said, I went through A couple of bov's that vta and I got to say recirculating my evo 9 stocker is the best thing I did, better throttle response and no F'N surges.
Old Dec 21, 2011 | 10:06 PM
Bones_OZ's Avatar
I bet the people behind love a rich running Evo.
Old Dec 22, 2011 | 06:27 AM
Originally Posted by wazzelby
I have to disagree with this statement. When you recirculate the air it's going to take the path of least resistance. If you push it back into your intake pipe it's going to try and charge the pipe (pressurize it) so the air will rush in and try to enter the turbo but will also flow out the filter where there is almost no resistance. So if the air reaches the turbo and encounters resistance, it will go back the other way and exit out the filter side. This is why you can hear the blow off valve much more with an open filter as opposed to a stock type of filter.
But as others have stated, recirculating will keep your car from running rich between shifts. Some people notice this more than others.
I whole-heartedly disagree with your disagreement lol. The reason you hear the discharge more is because there is less muffling. One major reason for stock intake designs is to keep this noise as quiet as possible. If you've seen your fair share of newer factory airbox designs, there is a lot more to them than just air passing through a filter.
If your theory was correct, air would STALL in the MAF every single time you recirc'd the BOV. There isn't zero resistance going through the filter, it has a great deal of vacuum being applied across it. Combine that plus the constant vacuum being applied at the turbo inlet and you have enough to direct the recirc flow away from the MAF.
-Jamie
Old May 8, 2012 | 10:32 PM
TrackBeast's Avatar
Yeah the best part of recirulating the bov is for the performance if you do happen to vent it, its only for the cool factor. My bov is recirculated right now and it makes me look bone stock.
Old May 8, 2012 | 10:46 PM
evo8426's Avatar
I vent the stock DV to atmosphere, only because I am running speed density.
Old May 15, 2012 | 01:46 PM
JDMEVOLEX's Avatar
I also heard that evo8s can't really recirculate because of running lean issues. Evo9 is fine. Is thr true ? I have Hks bov which is recirculated as well but im trying to get tial bov.
Old May 15, 2012 | 03:24 PM
foxbear2277's Avatar
Is it a myth that recirculating also helps with transient response between shifts since that air that would be blown out to atmosphere would in turn be sent back to the turbo?? I can see spool be better in between shifts, in for answers whether it is a myth or actually adds performance... when compared to vta that just adds more excessive noise (love the noise on a proper set up)
Old May 17, 2012 | 07:36 AM
peterbhoang's Avatar
I could be imagining the same thing but when i ran a recirculating compared to a vta, it seemed like my spools going in the next gear were much quicker.
Old May 17, 2012 | 07:40 AM
korizmo's Avatar
I'm venting 1/4 of my air to the atmosphere with a fast go bits bov. When shifting under partial throttle at 14.1 AFR's it drops to 11-12. So there you go. Runs rich in between shifts and thats all I have noticed.
Old May 21, 2012 | 09:05 AM
DRTHVDR's Avatar
I also find the noise of the HKS SSQV to be...a tad childish.
Old May 22, 2012 | 08:41 AM
211Ratsbud's Avatar
Recirc does help with response. Als/sas users noticed it works better with a recirc. Also no after air filter openings for dusty conditions to creep into.
DJErickG
17
Jan 29, 2015 09:33 PM
rbmxer
16
Dec 26, 2012 02:26 PM
2012evogsr
19
Dec 8, 2012 07:05 AM
Bergen Automotive
11
Aug 31, 2010 11:30 AM
HPEVOX
27
Apr 14, 2010 06:23 PM
