Help: Window Deflectors
Old Oct 28, 2011 | 04:58 PM
polish_pounder's Avatar
Hey guys wondering if there is a How to on installing the Window Visors? i read the instructions and it looks like its detailed ahha and i need some materials that i dont understand y so just wondering? thanks!
Old Oct 28, 2011 | 05:26 PM
dastallion951's Avatar
as in the window vent visors you only need like a flathead screwdriver, umm your setup should have come with some 3m tape to help mount it, the rest is pullin down the top liner on the doors to install the mounting tabs...make sure you double check where your gonna set down the 3m tape during the install make sure its right on, and iirc your suppose to leave a small gap at the back side of front doors, and a small gap on front side of back doors.
Old Oct 29, 2011 | 06:43 AM
Ok it said i needed some like cleaner n ****? I donno but the tape is on it i got it from Mitsubishi parts.net
Old Oct 29, 2011 | 05:42 PM
atcmac3's Avatar
it is very easy, clean area, install clips under rubber in the window, install visor, adjust clips to lock in. takes about 30 mins total.
Old Oct 29, 2011 | 06:20 PM
i used rubbing alcohol to clean the surface where the tape strip is gonna be applied that way no fine debris can affect the adhesive and it makes a good stick. the tape should be a 3m style tape, i believe thats what came with mine when i installed then, mine are oem as well.
omniprobe
Jun 18, 2017 02:57 PM
Tokuisport
Jul 8, 2010 10:01 AM
ixopnoydjoci
23
May 22, 2005 08:00 PM
nds34d
Apr 16, 2004 12:38 PM
WRXSLAYER
Aug 24, 2003 10:22 AM
