fuel pump rewire
Old Mar 1, 2014 | 06:56 AM
  #46
WikdEvo's Avatar
Gonna revive this thread so that I can get the specs on the relay. Just need the amperage specs so that I can replace mine.
Old Mar 2, 2014 | 08:30 PM
  #47
Oxford's Avatar
Nice write up
Old Mar 3, 2014 | 05:02 PM
  #48
wizzo 8's Avatar
It says amperage right on the relay
Old Mar 3, 2014 | 06:42 PM
  #49
WikdEvo's Avatar
Now if I only had a relay.. Sheesh.
I figured it out already.
Old Mar 27, 2014 | 11:50 AM
  #50
Ralliart004's Avatar
Veteran: Air Force
Another bump to a good thread I actually had to look this up after my oem fuel pump relay under the dash took a crap under full load at a track day almost a year ago.
Long story short that oem relay that only costs a couple bux cost me a cylinder rebuild and the only way the car would start was having to hardwire the pump. Unknown to me the piston was damaged and it drove from austin TX to san antonio TX under its own power thanks to this handy thread.
Thanks again! Cheers!
Old Jul 5, 2014 | 05:17 PM
  #51
Eisen7's Avatar
So just wanted to confirm this method hardwires the pump and bypasses the factory relays so the ECU can no longer control high/low voltage based on load/rpm?
Old Jul 7, 2014 | 06:57 PM
  #52
wizzo 8's Avatar
Yes
Old Nov 28, 2014 | 09:44 AM
  #53
AreSTG's Avatar
going to bump this from the dead again, because it's a great thread.
So, does anyone know, or have a wire diagram showing which wires are what? I am about to rig a pump inline with my main 255, and want it running full time like the main 255. Not talking about a 2nd pump with a hobbs switch, or relay from AEM, just a second primary pump that runs off the keyed power like the primary 255.
I guess I'm really just looking for the signal wire to splice into a second relay...
Hope that was clear, i feel like i wrote the same thing 3 times.
-Cheers
Old Nov 29, 2014 | 12:04 PM
  #54
AreSTG's Avatar
alright, did some process of elimination off your pictures and colors. Obviously, with out this specific kit, using these colors, just using colors means nothing in my case. I need relay connector numbers.
Anyway, I'm deducing that your "black wire of the relay goes to the white wire in the vehicle wiring harness that was cut earlier" statement is telling me the white factory wire is the 12v switched signal. Making your black relay harness wire going to "86" on the relay.
going to run with that for now...
EDIT:
For anyone who cares, the white wire from the OEM harness is the one you need to have a switched ignition source for a pump.
Old Apr 10, 2015 | 08:07 PM
  #55
maksim's Avatar
I know this is an old post, but I noticed you used the supplied ground wire to ground the fuel pump and used the ground wire coming from the car's harness to ground the relay coil. Would it make a difference if you flipped them around?
Old Apr 11, 2015 | 08:04 AM
  #56
wizzo 8's Avatar
Yes it wont be as efficient because of the gauge of the wire from the cars harness isn't as big so it wont flow the same amount of current.
Old Apr 13, 2015 | 06:12 AM
  #57
Veteran: Air Force
Bump to the Monday hump
Old Apr 13, 2015 | 07:04 AM
  #58
WikdEvo's Avatar
Why did you bump?
Old Aug 19, 2015 | 12:07 PM
  #59
Evonv91's Avatar
Huge help thanks!
Old Nov 24, 2015 | 02:12 PM
  #60
ineedboostman's Avatar
450lph
I'm going to drop in a 450lph. I'm looking to run it with e85 on an FP black. Is absolutely necessary to do this rewire? Is there anyone one running a 450 without a re-wire?
