How to make cheap coil on plug setup
Old Dec 6, 2011 | 05:59 AM
  #46
jonmorera's Avatar
From: Costa Rica with business addres in Miami FL 33166
Originally Posted by nuk1ear
you didnt get everything i said did you?
They will run double the number of spark discharges, but also you dont know if the dwell time is too high or too low. Too high and you get premature wear and too low and you get a crap spark. Why change when you technically get the worst of all worlds? Either go standalone or nothing IMO. These reviews of COP being a whole world better and giving 20horses just sounds retarded to me. Maybe i should try it so i can see the light...............
COP uses 4 wires denso coils of the toyota yaris, honda uses 3 wires denso coils, both coils are and make the same, if COP had this proved and found all these benefits, what is the problem??, I can see that the setup is one of the best upgrades that we can do to our Evos. Is proved that the spark is greatly improved.
Simply this setup works and works great!!!!
Old Dec 6, 2011 | 06:50 AM
  #47
jonmorera's Avatar
lol..........................but the lack of logic
With this I will convince you.
You know the old systems of ignition? one coil for the four spark plugs and the distributor distributes the sparks, the old ignition systems make the double of discharges compared to this coil on plug setup, Understand???.
Old Dec 6, 2011 | 07:14 AM
  #48
FX11's Avatar
Originally Posted by 10isace
I saw that, but those have 4 wires. Is there a write up for the evo? I saw those on a Miata site here
Wires go to:
  1. ground
  2. trigger
  3. 12V
  4. tach
Thanks for the Miata Link, I will be doing this to my Miata now and see how it does. If I do see a difference, then I will do it on my evo
Old Dec 7, 2011 | 01:27 AM
  #49
nuk1ear's Avatar
haha, yeh but i dont see what that has to do with this at all lol. anyways, Would love to see back to back dyno runs from this
Old Dec 7, 2011 | 09:24 AM
  #50
Mauricio Evo IV's Avatar
Originally Posted by Steve220
I ran one and back to back with the original coil packs and it made a massive improvement. Also i removed the OE earth line from the wiring harness and made one to earth on the engine black, so it was much shorter and larger Don't know if it helps, but in the end the OE coil packs earths next to the thermostat housing, almost a metre of wire :s
I made it mine today! I hope to get good results!!
Old Dec 7, 2011 | 09:32 AM
  #51
ihockey1's Avatar
https://www.evolutionm.net/forums/ev...d-results.html
Old Dec 7, 2011 | 05:14 PM
  #52
10isace's Avatar
Originally Posted by ihockey1
i think the tach wire is left unused since evo's pickup tach signal from somewhere else, but i could be wrong
Can anyone verify this?
Old Dec 7, 2011 | 09:11 PM
  #53
716amg55's Avatar
are there some nice looking cover plates that fit with these diy cop's so they look a little better?
Old Dec 8, 2011 | 09:22 AM
  #54
211Ratsbud's Avatar
Is the cop any different for a 9? Like deeper coils etc.
Old Dec 8, 2011 | 01:06 PM
  #55
vortico's Avatar
How do you know if used coils are good? There anything to look for, other than there being something obviously bad like physically broken or burned or something...
Old Dec 8, 2011 | 06:51 PM
  #56
vortico's Avatar
Saw on another forum (lancerregister.com) this post: http://www.lancerregister.com/showpo...4&postcount=39
Guy said he used yaris coils and a harness from a "MAZDA PREMACY OR MAZDA RX8 its from the the harness at the radiator" to connect the coils to the evo oem connectors. Anyone have any idea what harness he is referring to? I am in the process of making an account on that forum to ask but its taking forever lol.
Also if you make your own harness what part from spoolin-up is used? EVO 4-9 Coil Connector - Crimp Male connector right?
Old Dec 9, 2011 | 05:56 AM
  #57
jonmorera's Avatar
yeap you need two connectors:
""EVO 4-9 Coil Connector - Crimp
Easy to use crimp-on connector for 18ga (16 ga Tefzel) wire and larger. Comes with 1 Connector, 3 Seals and 3 Terminals. Typically two are needed. Priced per unit.""
Old Dec 9, 2011 | 07:20 AM
  #58
vortico's Avatar
Sweet thanks
Old Dec 9, 2011 | 11:18 AM
  #59
211Ratsbud's Avatar
Anyone /
Old Dec 10, 2011 | 06:00 AM
  #60
jonmorera's Avatar
Anyone /
Evo 8 and 9 uses the same coils!!!
