Deleting rear o2 sensor for wideband
Old Jan 10, 2013 | 08:10 PM
MrSquirr3l's Avatar
bump i am looking for the patch o2 aswell. any help would be appreciated!
Old Jan 10, 2013 | 09:23 PM
Raptord's Avatar
Do an advanced search for "P0037" in the title. There are a couple threads with the code you need to add in them.
Old Jul 16, 2013 | 03:30 PM
CNOEVO22's Avatar
Fat chance anyone cares but why not drill a hole in the pipe and weld a bung in for the wide band sensor. Then you don't have to worry about codes
Old Jul 16, 2013 | 05:50 PM
JaYr_EvO9's Avatar
you could do this but if your getten it tuned have the tuner delete the rear o2
Old Jul 2, 2014 | 11:02 PM
00ASIAN's Avatar
IM new to the evo scene and learning about my car everyday. My tuner suggested I go from my aem standalone to stock flashed ecu since my evo is my daily driver. My evo had no o2 sensor. How much will installing a 02 sensor help with driveability and fuel efficiency?
Old Jul 5, 2014 | 04:42 PM
BadassEvo8's Avatar
Just run Tephra rom? You can plug the rear o2 sensor and delete the check engine code. Either that or run a wideband to the rear 02, plus rear 02 is useless anyways especially if you have a test pipe, or no cat.
Old Jul 8, 2014 | 07:07 PM
Atomic646's Avatar
Originally Posted by badassevo8
just run tephra rom? You can plug the rear o2 sensor and delete the check engine code. Either that or run a wideband to the rear 02, plus rear 02 is useless anyways especially if you have a test pipe, or no cat.
Luckystryke
May 31, 2016 05:38 AM
Chuckdimpala
10
Jan 27, 2015 07:28 PM
lalexl
Jan 17, 2014 08:19 AM
boy36
14
Dec 24, 2009 09:57 AM
AbrasEvo
Jun 4, 2009 10:42 AM
