Relocation of Boost Gauge
Old Apr 6, 2012 | 09:28 AM
ahr4156's Avatar
Hi,
Im having some trouble relocating my boost gauge. This is where it is wired.
How would I move it to the steering wheel area?
Thanks!
Old Apr 6, 2012 | 10:06 AM
wazzelby's Avatar
I'm not sure exactly what you are asking? Moving it is very straight forward.
1. Disconnect the boost gauge from where it is.
2. Move it to where you want.
3. reconnect the wiring under the dash.
Easy
Old Apr 6, 2012 | 10:15 AM
ahr4156's Avatar
I'm not sure where the wires are going to. The previous owner wired it. I can push the wires through the hole but then I'm not sure where to get them from. Would I have to pull up the dashboard to get to it?
Old Apr 6, 2012 | 03:55 PM
sujinX's Avatar
from the looks of it, u can prolly get at the wires from under the dash, or might be able to get to it if you take out the radio/ac center portion of the dash.
every wiring is different, you have to just take what i mentioned and look for the wires. no one can tell you how its wired just from that pic.
its very straight forward, you will see wires that dont belong there.
Old Apr 6, 2012 | 06:12 PM
Chef-j's Avatar
^+1. You can get them out under dash on driverside. It would be easier to look if you move radio.
Old Apr 7, 2012 | 06:29 AM
ahr4156's Avatar
Thanks guys!
Old Apr 7, 2012 | 07:34 AM
vortico's Avatar
You may also need to remove the bit of trim that goes around the AC vents/clock (carbon bit on an 9). That gives you pretty good access to the area where those cables should come into the dash. That's how I currently have my gauges mounted.
Old Apr 8, 2012 | 08:52 AM
ahr4156's Avatar
Yea I had to remove the AC vents/clock and it was behind one of the vents.
shadovarian
Apr 12, 2013 11:08 AM
Mark@AMS
Evo 'For Sale' Exterior Styling
43
May 13, 2011 10:33 PM
turbodreamz21
For Sale - Cars For Sale
Jan 17, 2010 04:40 PM
AlvinHuyN
Jun 14, 2008 02:01 PM
mikec
Oct 2, 2003 11:01 AM
